Question about Dishwashers
Dishwasher will not drain
Has a pool of water in the bottom
  • Anonymous Dec 23, 2008
    my dishwasher wont drain
MY BOSCH EXXCEL DISHWASER WONT DRAIN?
Posted on Dec 18, 2008
Water collecting at the bottom of dishwasher, used it for the first time and there is a big pool of water at the bottom of the dishwasher when i open up the drawer
Your drain might be plugged. Check the bottom drain. If the water has no where to go, it will fill the bottom up. There might be a cap since it is new. It has to have a place to drain.
Feb 16, 2011 | Electrolux 23 in. ESL6114 Built-in...
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 02, 2011 | Dishwashers
The water is not emptying from the bottom of the machine..leaving a constant pool of water. help?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Is a small pool of water in bottom after dishwasher has finished
check the air gap for the blockage,or the underneath of the pump screen
Jul 31, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher not draining
typically either the timer switch or the pump.
If the cycle operates normally, but the unit doesn't drain, then I would suspect the pump.
If you remove the drain hose directly from the the bottom of the dishwasher (be ready to catch some water), sometimes you can clean the junk out of the pump and make it work again.... If not, it's right there and ready to be removed.
Good Luck!
Nov 27, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Mar 29, 2007 | Kenmore 24 in. 15074 Built-in Dishwasher
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
