Question about Dishwashers
Top propellor fell off
Can I still use the dishwasher. It is a miele premier.
What does the top propellor do? Do i need to get it fixed?
  • 8,197 Answers
Yes you can still use the dishwasher. The top propeller just gets watter to the top area. It will still work but the top area will not get that clean. I recommend repairing it ASAP so you get the best washing from the machine.
Posted on Dec 17, 2008
Nouveau dishwasher
Fixya is unable to identify parts sources.
Dec 15, 2017 | Dishwashers
I'm getting F 84 which i'm told is failure of the divertor. A new pump is more than the value of the machine. What can I do? Can I get a reconditioned pump, or can this problem be fixed?
That was a very expensive dishwasher...I don't know what you were quoted but I did find one site (British, of course) that offers replacement pumps for far less than the cost of a new Miele...hope this helps...
http://www.espares.co.uk/parts/dishwashers/pumps/miele/p/1537/254
Nov 04, 2012 | Miele Premier-Plus Built-in Dishwasher
Upper sprayer arm fell off
I had the same problem and it was due to cheaper tablets that corroded the plastic. Used the recommended tablets since replacing the arm (easy to refit) and now use Finish tablets all the time. Sorted.
May 20, 2012 | Miele Premier-Plus Built-in Dishwasher
COST OF CONTROL BOARD MIELE DISHWASHER G841
best to call your local Miele service agent or Miele office as the price will differ depending serial number and the county you live in with the exchange rates etc
Jul 13, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
The 'inlet/outlet' red indicator light flashing, small pool of water collected under filter, but cannot get back of to clean it. Model is Miele G646sc
You might be able to reach if you take the sides off. Elect disconnect, open door, remove 2 cross head screws recessed at top of where door closes, push top cover backwards an inch then lift off. remove 2 screws at top of each side panel then the lower ones (4 a side) panels then lift off and you can see right across the bottom of the 'sump' including the float switch assembly. (which has no effect on switching on the inlet/oulet lamp on my d/washer.)
Nov 10, 2009 | Miele Premier-Plus Built-in Dishwasher
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Door problem
on my machine there is a torx screw at the top left hand side. You need to open the door to see the screw which sits behind the off-white flange (look for a hole in the flange).
Oct 22, 2007 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
