Question about StarTech.com StarView SV211K 2-port KVM Switch
Channel edit option has gone..
I went into factory settings on pressed ok,now i cannot get into my patental control and channel edit.I cannot not get back to the channels that still dont work anyway.the page with english etc keeps coming back up even when i exit.i have pulled the plug to start again but cant seem to get back onto the channels.please help!!!
    Problem Solver:
  • 8 Answers
Switch off take batterys out of remote plug back in after 30 secs insert batterys try again should sort your prob mate send me your codes to check also kiki
Posted on Dec 17, 2008
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Tip
Sciphone i68 AT&T GPRS & MMS Internet Settings
Thanks to the author, follow these steps:
GO TO SERVICES AND FOLLOW THE FOLLOWING:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT ANY OF THE PROFILES LISTED(EXAMPLE CHINA MOBILE)
A SCREEN SHOWS ACCOUNT NAME, APN, USER NAME AND MORE
EDIT ACCOUNT NAME TO AT&T, GO ON OPTIONS AND PRESS DONE
EDIT APN EDIT TO wap.cingular (lower case), GO ON OPTIONS AND PRESS DONE.
EDIT USER NAME TO WAP@CINGULARGPRS.COM (UPPER CASE) AND PRESS DONE.
EDIT PASSWORD TO CINGULAR1 (UPPER CASE) AND PRESS DONE.
EDIT AUTH. TYPE TO SECURE.
SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
GO BACK A COUPLE OF TIMES UNTIL THE OPTION WAP AND DATA SUPPORT APPEARS AGAIN
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT SIM 1 OR SIM 2 (OTHER SIM NEEDS SETUP IF BEING USED ALSO)
IF AT&T APPEARS SELECT IT, IF NOT EDIT ANY PROFILE AND RENAME IT AT&T.
SELECT EDIT PROFILE
GO ON HOMEPAGE AND CHANGE IT TO http://device.home lower case)
GO ON DATA ACCOUNT, THAN GPRS, AND SELECT AT&T.
GO ON CONNECTION TYPE, ITSHOULD READ HTTP, PRESS ON IT, SELECT HTTP
ENTER PROXY ADDRESS 066.209.011.032
ENTER PROXY PORT 8080
PRESS OK THAN SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
SELECT ACTIVATE PROFILE( ATT WILL APPEAR AS SELECTED)
THE PHONE IS READY. GO TO SERVICES AND SELECT HOMEPAGE FOR INTERNET.
MMS SETTINGS
1. Select Messages
2. Select MMS
3. Select MMS Settings
4. Select Edit Profile
5. Select any profile
6. Choose Edit Profile
7. Edit Rename Profile to AT&T MMS
8. Press Options
9. Press Done or OK
10. Edit Home Page to http://mmsc.cingular.com
11. Press Options
12. Press Done or OK
13. Select ATT MMS and press OK
14.Edit Connection Type to HTTP
15.The IP address is 066.209.011.032 and the port number is 8080 and press OK
16.Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
17. Press Options
18. Press Done or OK
19.Edit the Password to CINGULAR1 (UPPERCASE)
20. Press Options
21. Press Done or OK
22. Press Done
23. When prompted to SAVE please select Yes
24. Select Activate Profile and yes.
on May 08, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
It is on retail store mode - how do i get it off this
Hello
Surf throug its menu options and come to parential control window. The parential contro default code is 0711. There you can see the option "Reset". Select it, and press enter. All the channels and programmes will be reset to Factory settings. you can adjust allthe settings according to your taste later. OK.
Mar 19, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hit the reset button on remote and now tv is not finding any input signal sources. I have checked the connections and everything is the same as before so tv will not do anything. Also not finding any...
hi,
when you press the reset button the tv has gone to factory setting. All the settings made by you have been erased when you rested the tv. you have to set all channels by auto tinning your tv. also you have to set picture setting according to your preference, because the tv is now in factory default setting.
ok
Feb 14, 2011 | Sanyo DP32746 32 in. LCD Television
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Some channels have gone went to menu 1570 by an accident presed ok on set default key now channels gone except for rte1 please help thanks
go back in press 1570 go to your subscriber make sure your keys /codes have not changed then scroll down to key emu and turn on hope this helps
Jun 22, 2010 | StarTech.com StarView SV211K 2-port KVM...
Restricted channels cannot figure out how to reset to factory settings
Pressing the menu button should bring up options to adjust the color ,tint,etc. look for antennae options or parental control options to lift the restricted channels. hope this helps.
Bobalix
Apr 18, 2009 | Televison & Video
Cant exit menu on 'the box' digital receiver
hi i went in to factory setings and pressed 0000 now am stuck on language and cant get bac to any channels can any1 help us plez
Dec 20, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
35 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
