I have a gateway mx3210 and I am trying to restore it back to its factory settings, but I lost my System Recovery cd.
  • 61 Answers
Turn on or restart your computer, then press R when prompted to start the recovery
process
and follow the on screen instruction
Regards
Samson Ved
Posted on Dec 17, 2008
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
How do you reset to factory settings on the gateway ZX4931-31e
Click on Start -> All Programs -> Scroll down to Gateway (or type Gateway in the line) -> click on Gateway Recovery Management -> click on rider "restore" -> click "Restore System to factory default".
May 05, 2011 | Gateway ZX493131e Notebook
How to reboot my gateway nv53 laptop to factory without a cd bought this laptop used starting to have problems so i want to erase everything and make it like new
Hi.
The laptop may have a hidden recovery partion which you can access from boot up. Turn the laptop off and then restart it. When you see the Gateway logo hold down Alt and repeatedly press the F10 key. From there follow the on-screen instructions to restore the laptop to factory defaults, it should take about half an hour but could be longer.
Remember to back up any data that you want before you restore the system.
If you can't access the recovery partition then you can use Windows to do it for you. Click on the Start Menu> All Programs>Gateway and then Gateway Recovery Management. In the Gateway Recovery window click on Restore and then select Restore System to factory default and follow the on-screen instruction. The computer will restart and proceed with the restore.
Regards.
Apr 27, 2011 | Computers & Internet
How do i reset my hp computer back to the way i bought it?
factory settings could mean performing a system restore to a previous state of the OS. I'll try to explain how you can perform each one of these methods in the article below.
Restore Factory Settings - System Restore System Restore is the in-built tool of Windows XP and Windows Vista that allows you to roll back the registry to a previous state. Note that it only "restores" previous settings for the registry and Windows system files.
You can use system restore to get rid of spyware, but if system restore does not fix your problem, you'll have to resort to either a clean install of the OS or using your recovery CD/DVDs.
You can read my previous post on how to restore your computer using the System Restore feature. If system restore is disabled, you can read my post on how to enable system restore again.
Restore Factory Settings - Recovery CD/DVDs Most computers come with either a recovery CD/DVD or a recovery partition that is hidden on the computer. This is true for most HP and Dell machines now these days.
If you have one of these, you can access the recovery from within Windows or during startup.
For HP, you can go to Start, All Programs, HP Tools, and then choose HP PC System Recovery.
You can also press the F10 key multiple times during bootup to get access to the recovery console in case Windows is not loading properly.
On Dells, you can access the recovery partition by pressing Ctrl + F11 immediately after the machine is turned on.
Note that all of your data will be lost on the hard drive. Using a recovery CD is not the same as repairing XP. When you repair Windows XP, all of the system files are replaced with the original ones, but your data and applications remain intact.
Restore Factory Settings - Clean Install XP Your last and final option for restoring XP to factory settings is to perform a clean install. This requires having the CD/DVD for the OS. If you only have a hidden recovery partition, you will not be able to perform a clean install.
A clean install basically consists of booting from the original XP CD, deleting all partitions, recreating new partitions, and then installing Windows XP from CD.
It's a fairly straight-forward process and you can read this excellent tutorial for step by step instructions. Again, it's important to note that you will lose all your data in this process.
Oct 05, 2010 | Computers & Internet
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
I have a gateway gt4010 with some virus, i reinstalled recovery CD, but it showed "window root" error message w.hal.dll missing... can you to give some tips on this?
Most Gateway systems can be restored to factory settings using the following steps:
Turn on the system and repeatedly tap F11 key (before windows starts to load)
In the System Restore Options dialog box, click Full System Restore (with Backup), and then click Next.
Wait for the recovery process to complete.
Thanks
Mar 07, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Can i restore my ibm x30 back to factory settings
Yes.
One way: take the "System Restore" set of CD-ROMs that were originally shipped with the computer, and boot from the first CD.
If you have lost those CDs, there may be a "recovery partition" on the disk-drive -- when you turn the computer on, look for a "Press F11 to enter Product Recovery" prompt. Press F11.
Contact IBM. For about $60, they will ship a replacement set of those "System Restore" CD-ROMs to you.
Nov 14, 2009 | IBM HARD DRIVE 30GB 2 5" 4200 RPM Thinkpad...
Trying to do a full factory recovery on an M Series gateway note
If you want to do the factory recovery, 3 ways to do the system recovery
First way
1 login to windows
2.click Start
3. click All programs
4. click Gateway
5. click gateway recovery manager
6. click restore
7. select systems recovery to factory defaults
Computer will restart itself and start doing the system recovery itself, All you need to do is follow the screen
Jun 07, 2009 | Gateway MX6447 Notebook
Still wondering if there is anyway to get my computer back to the factory settings. I dont have a recovery disc and have somehow lost my microsoft word program which I need desparately. I am not the...
you can restore your system to some back date where it's working fine through system recovery option, for this go to program - accessories - system tools - system restore option.
then select some back date where do you think your system is ok
Oct 10, 2008 | Gateway Computers & Internet
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
