Question about Kodak EasyShare C330 Digital Camera
I am getting an filesystem error e00100 when I put a brand new 2Gb SD Card into my EasyShare C330. Does the camera support 2Gb SD Cards?
  • Anonymous Dec 23, 2008
    This sucks kodak, I even bought your brand card!
This camera only supports up to a 1gb.
Posted on Dec 24, 2008
  • 78 Answers
I beileve the largest it can use is 1gb..
Posted on Dec 18, 2008
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
My kodak easyshare c330 will not format my brand new 2gb memory card e00100
Your problem is that 2GB SD cards did not exist when your camera was manufactured. It's only designed to handle a maximum capacity of 256MB.
Your fix is to replace the 2GB card with the lower capacity model, at the highest quality setting it's more than sufficient with a capacity for 307 images, and at the lowest quality it will hold around 893 images. In video mode it holds 10minutes, 50 seconds, but you may find that the battery runs out before toy get that far.
Mar 07, 2011 | Kodak EasyShare C330 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
Click
Dec 20, 2008 | Kodak EasyShare C330 Digital Camera
The largest memory card capacity of the Kodak Easyshare C330?
its not the card! all cameras do not read all the same ds cards...even tgough they may all fit I recomend a sandisk card!
Dec 10, 2008 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
1,163 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
