posted by petepage on Mar 26, 2007
The problem is that after several hours filming on timelapse the microscope light switches off and no further photos are taken. On exiting the programme the microscope will not restart unless the computer is rebooted. Windows 2000 states that the device is working correctly and all other devices will operate using the usb connection. The time taken for the microscope to stop filming has varied from 2 hours to 24 hours. The problem does not appear to be dependent on temperature since I have left running in a cold room. Will a usb connection 'timeout'?
Solution #1
posted on Apr 28, 2007
Depending on the model of your USB, (1.1 or 2.0) it may or may not time out. With a 2.0 speed USB it will not typically tome out until about 30 hours of very high activity use. A 1.1, on the other hand can get to do that a lot. If your USB is a 2.0 get a computer expert to check that it is not malfunctioning. If it is a 1.1, I would suggest getting a USB upgrade.
Comment by Nightraider, posted on Apr 28, 2007
If you can't figure it out, please email me at nightraider555555@yahoo.com
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Digital Blue QX5 Microscope
Email this problem
Email this problem
Can you Help with these Microscopes problems?
Problems with Resolution
When the program starts up and... Answer This...
Digital Blue QX5 microscope
When we have used the QX5 on a... Answer This...
Repair Service
Find Microscope Repairman Near You:
