Question about Maytag Neptune MDE5500AY Electric Dryer
Squeaking sound the squeaking sound is very loud at the beginning of the cycle and then lessens sometimes its gone completely but it seems to be getting worse
  • Anonymous Dec 17, 2008
    same problem.
Sounds as if your rollers are going bad.
You would have to remove the front panel and remove all the screws out of the front to lift top of dryer.
Do not remove any screws out of the back, it will release your drum stabilizer.
Posted on Dec 19, 2008
VERY LOUD SQUEAL and SQUEAK right before the RINSE cycle. it's scaring me! thanks for your input.
Hi Margaret,
Does the tub/drum come to a complete stop prior to the rinse cycle beginning? Are there any belts or is it direct drive? Does it pump the water during the rinse cycle? If nothing is moving it could be the impeller on the pump is slipping, but likely it would have already come loose. The pump itself usually just fails completely without the squealing and squeaking part. If someone could be sure nothing is pushed up against any other moving parts it would be of help. It often happens when belts are involved and the drum is being turned it does just what you are describing, until it gets to speed.
May 17, 2016 | Washing Machines
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Very loud squeaking
My guess is a pully is going bad on the tensioner. The new belt had more grip so it was able to force the bad pully to turn but now that the new belt is a bit worn it's beginning to slide as the pully gets worse...Does tha make sense? Solution: Remove the belt and turn each pully by hand. The pully's should turn very easily without ANY struggle. If you find a pully that has any stiffness ...(Or is hard to turn).....thats the bad one. Replace the bad pully and you will be a happy camper
Mar 27, 2013 | 2002 Hyundai Santa Fe
Dryer runs and heats but has squeaking noise. Drum seems to labor mid cycle and then shuts off. If I turn cycle to off and wait unit will resed and begin cycle again with normal heat. Squeaks in on off...
Hello & Welcome to FixYa
The squeaking sound comes when the belt is either broken or worn out and needs replacement or the idler pulley is bad. If you want to do this yourself then you can check this video on YouTube:
Please get back to me if you have any other questions.
Kevin
Jan 30, 2011 | Kenmore 73932 Gas Dryer
When the dryer begins its process, a long loud "squeaking" sound erupts, the dryer still dries, but this sound may last 5 - 7 minutes, then the squeak diminishes to a soft squeaking sound the remainder of...
The noise is likely coming from a roller which keeps tension on the belt which wraps around the drum. This roller will sometimes squeal as it wears on the shaft to which is mounted Follow the instructions below to replace the Idler roller.
Pull the dryer out enough to get behind it. there is a lower black panel to be removed by taking out all the 5/16" screws around the edge. Swing the panel aside and look into it. You will see the motor to the right. The roller should be between you and the motor. The configuration looks like the picture at the link below.
The belt goes in the grooves on the motor pulley and the flat side runs around the idler pulley, according to the GE chart on this image.
http://www.applianceaid.com/images/belt-config.JPG
Oct 28, 2009 | GE Dryers
WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Gradual squeaking increase
Check the drum's roller bearings - they sometimes look like large rollerblade wheels. The may need to be replaced. They are relatively inexpensive, and can usually be found at your local appliance parts store.
Too, check for a  felt "ring" around the front of drum (if applicable). Again, if too worn, replace it.
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Maytag Neptune MDE5500AY Electric Dryer Logo
143 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
