Question about Zebra S4M Thermal Label Printer
Tlp3842 printing every third label, need to change size
If you are using windows go to Start, Printers and Faxes. Right click on your printer and select Printer Preferences. Under the Advanced tab there should be an area where you can change the dimensions. You'll want to change the Width and Height to match the dimensions of the label that you are using. These are usually in inches or inches/100. Ex: 1 inch = 100 in/100.
Posted on Jan 08, 2009
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
The printer is new. When you press the feed button,it does dot feed 1 label. What do I need to do to correct that?
First download a driver ans install it.
Second program your label size.
Third Select the correct settings (Detection, protocol etc..)
Print a label.
Now when you press feed you'll get a label
Aug 15, 2011 | SATO CL608e Thermal Label Printer
When we open the print option and select the label printer it won't give us the option to print on labels, only on much larger sizes of paper
This because you might have kept the larger size catridge so that you wil not be able to print smaller size labels.please change small size catrige so that you can print what size you want.
Thanx
Jul 21, 2010 | Brother P-touch QL-550 Thermal Label...
Print labels created in ms access
first check your driver for zebra 2844 it is compatible with the OS, if it's Ok may be you can find third party software that help us create label
May 13, 2010 | Zebra TLP 2844 Label Printer
The barcode printing on the label is very large. I need it to be more 'compact'. How do I change? What are my options? Thanks.
Select the correct label size in the printer setup.Go to printing preference in driver and changet label width and height according to label which you use.Eg: 52MM and 25MM
when label is large double click the barcode and decrease font size according to your label size.
Aug 03, 2009 | Zebra S4M Thermal Label Printer
Printing quality TLP3842
clean the printhead, if no better replace it
May 15, 2008 | Zebra TLP 3842 Thermal Label Printer
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
Zebra S4M Thermal Label Printer Logo
136 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
