Question about Whirlpool GB2SHDXP Bottom Freezer Refrigerator
Change door opening direction on whirlpool fridge door
I have a bottom freezer fridge on which the handle to open the door is currently on the left hand side - I would like it to be on the right hand side. However, the hinge which sits on the freezer door and on which the fridge door rests does not work on the opposite side. All other parts work fine - what am i doing wrong?
thanks!
  • lisebunt Dec 17, 2008
    thanks for the manual....however my center hinge does not look like that - which must be my problem! the center hinge - when used on the reverse side makes the freezer door rest too high for the holes on the fridge to work with the hinge....
    any other ideas? do you know of any whirlpool fridges that come with 2 hinges in case you want to reverse the door?
    thanks!
  • 8,197 Answers
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
  • Jyackle5
    Jyackle5 Dec 17, 2008
    Also for the middel hinge you need to remove the plastic capes where you want to put the new hinge location they just pull straight out tourds you. Then put them in the old holes where the hinge was.
  • ldrcleaning Sep 19, 2010
    Manual does not show the handle that is now currently installed on the Whirlpool model gb2fhdxws 03 with a freezer drawer. Manual is out of date. We can not figure out how to get the handle off the left side to install it on the right side.
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
How do i remove the handle of my whirlpool fridge?
you may need a new door,,or use the top door just up-end it and put it on the bottom?
Jul 04, 2010 | Refrigerators
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Feb 26, 2018 | Whirlpool ET1FTTXK Top Freezer...
I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Apr 24, 2010 | Refrigerators
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Change doors of fridge freezer from right opening to left opening needless to say cannot find instructions after 10 years
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
Mar 13, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Can you change the handle on fridge? from left to right
Yes you change which side you want the handle You have to remove the plugs that are at the top of the fridge and at the the top of the doors. And also at the bottom. Exactly where you have the dorrs conected now look at the opposite side and in the same positions you will find these plugs. Just remove them and reverse them to the oteh side. I hope this helps. Don't forget to rate my answer, thanks
Feb 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GB2SHDXP Bottom Freezer Refrigerator Logo
7,427 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
