Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool 29"gas dryer Model#LGN2000LW1
Dryer will not heat up. only blows cold air on the highest heat
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    Jd, this can get complicated to explain. First you'll need to tell me if you have a multimeter. You'll need to do some testing with it to determine the failed component. All we'll need to check are ohm's. So let me know, then we'll proceed.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Dryer no heat blows cold air what s a common fix gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
heatman101
Oct 09, 2010 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Mar 04, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
No heat, loud noise when drum spins
This is a different symptom than the one you requested earlier... This symptom suggests that the coils (booster and holding coils) at the burner valve have failed and should be replaced.
First, UNPLUG THE DRYER!
Gain access by removing the lint filter and removing the two screws that were hidden under there. Now take a flat screwdriver and pry the top panel up (like the hood of a car). There are two clips on each side.
Now the the top is up, disconnect the door switch (it's there on the right). Now look at the front panel from the inside... you'll see a screw on each side (they're 5/16" drive), remove them. Now tilt the panel out toward you about 3 inches, starting from the top. Now lift the panel one side at a time to disengage the clips at the bottom. Now set the panel aside.
You'll see the burner assy. on the lower right. On the top of the burner are two black coils held down by a bracket. One coil has two wires, the other has three. Remove the wires and remove the bracket. Lift the coils out (noting how they were installed) and replace them with new ones.
Rebuild is the opposite of tear down.
Hope this helps! Let us know how it works out for you, OK?
Dec 17, 2008 | Whirlpool GGQ8831L Gas Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
115 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
