Question about HP Computers & Internet
The door to the DVD "platter" on my HP desktop opens and closes or remains open w/o any activity on my part. Perhaps I may have pressed something to initiate this strange behavior which is most irritating. I'm hoping I can press something to stop this recent development. My HP desk computor Microsoft Windows XP Media Center Edition 2005 Product number is: EX278AA-ABA. The serial number is: MXX6230BFB
  • 115 Answers
It is a fault with dvd. Dust can be a reason. Anyway need servicing.
Posted on Dec 17, 2008
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Dell XPS 435T/9000 Drive F drive tray auto opens and closes. Will not remain closed after CD drive inserted. Can activate open and close ok from side switches, but drive tray will not remain closed with or...
That's probably someone who pranked you by setting scripts or programs on your machine to do that. Just run dtrace or something to find out what programs are looking at media status (for 'closed') and decide whether any of them aren't familiar. Depending on your OS it could be a pretty small script or program....
It may on the other hand be something familiar whose backup function you haven't used or addressed in a while....
May 23, 2011 | Dell Studio XPS 435 PC Desktop
Hp xw8400 drive door wont open after it reads a
Straighten a paper clip and push it inside the small hole just above the open/close button while you press the button. You'll need to apply some force. This is usually caused when the gear inside the cd/dvd rom is not working properly or damaged. Good luck. Thanks for using FixYa.
Jun 04, 2010 | X2 Hewlett Packard XW8400 X 2.33 2GB 160GB...
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Mar 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Keypad will close door, but not open it!
Try changing the battery and reprogam the keypad. The code remains active for about 30 sec. after it is entered into the keypad which allows you to press enter to change direction of the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cd/dvd door is opening and closeing all by it self
this is due to improper connection of wire from optical drive to motherboard i.e check whether the power cable/ide(sata)cable is not loose.Also clean their plugging area.problem will be solved.thanks.
Nov 23, 2008 | HP Pavilion a6544f Desktop PC
CD Rom wants to remain in Open position and doesn't read cds
There might be something jamed or lodged in the CD-ROM compartment which would be preventing it to close all the way so it wants to stay open.Hope this helps =)
Feb 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
