Question about Compaq Presario Notebook
Cant connect to internet i have a wireles contact usb
My provider says its not them some way my computer must have had a update and its not letting me connect even tho the connection is good
  • 1 more comment
  • Mark Robinson May 11, 2010
    can you explain what happens when you try to connect to your provider and what equipment you are using
  • Anonymous Mar 29, 2014
    I cant connect to network even tho I have connected to it before
  • 115 Answers
Open internet explorer and select connections. Select "always dial my default connection" and click on the name of the connection and click "Set default" ---- (if these are highlighted).
then click lan settings and check the box for "Automatically detect settings".
Posted on Dec 17, 2008
Can't connect to internet
Check all leads connecting to modem router ethernet ,usb for kinks bends and secure connections.
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Sep 13, 2013 | Computers & Internet
My map is outdated, how can I get an uptodate map
Go to the website for your GPS provider. There should be the latest update for every model of the GSP you own. Download the update to your computer. Your GPS should have come with a cable to connect it to your computer (through a USB connection). Connect your GPS to the computer and open the update file. It should automatically begin transferring the information over to your GPS for update. If this does not work, I suggest contacting the GPS provider, as they may have a very specific update process that requires driving to one of their stores. If you need anything else, let me know!
May 19, 2011 | MyGuide GPS
I cant log on to internet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
check the password make sure its exactly how you provided to your ISP internet service provider make sure the Caps lock is on/off which ever applies to your ISP contract
check your computers settings ie: firewall also he might have a default internet setting
check the leads from the modem/router whether usb,ethernet make sure they are not bad/faulty and have secure connections and try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
don
Feb 26, 2011 | Dell Computers & Internet
Tryed to update my magellan 4250 at mid update I lost my internet connection and the update stopped. Now all I get is a blue screen that says Magellan on and nothing else happens, Also my PC will not find...
If your PC does not see the usb when you connect it to the computer. Then it means you will need to seek further assistance from magellan, because the solution for the unit is to connect it to a computer, and since the computer is not reading it, then you need to get to a close by magellan center or you mail them on this link
http://www.magellangps.com/About-Us/Contact-Us
Hope this helped.
Jan 05, 2011 | Magellan Maestro 4250 GPS
I have a tablet pc and cant pick up the internet I have wireles Hope u can help
check if your computer has wireless switch, if yes, make sure it is turned on. also try to update the wireless driver of your computer by downloading the it from your computer manufacturer's web site.
Jun 09, 2010 | Toshiba Portege M200 Tablet PC
Error code 32004
Error Code: 32004 Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  5. If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
  1. Does your PC have any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.) installed? If you are using the Nintendo Wi-Fi USB Connector, and have a software firewall or other computer security program installed on your computer, there may be additional steps you must complete to allow a successful connection.
      "Trusted" Applications:
      If your firewall or PC security program keeps a list of trusted applications (also known as a "trusted zone"), the following programs are installed with the Nintendo Wi-Fi USB Connector, and require internet communications. If prompted by your firewall or PC security program, add these to the list of trusted applications. This information may also apply to certain computer security applications, such as anti-virus, anti-spyware, etc.:
      • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
      • Setup.exe (when installing the USB Connector)
      • SoftAPInstDrv.bin
      • mdriver.exe
  2. If you are using a router, you may need to temporarily disable the router's firewall to allow the Wii console to connect online and receive a system update. Once the update is received, you can turn the firewall back on. For information on locating and disabling your router's firewall, please consult the router's manual or contact the manufacturer of the router.
  3. If you are still receiving this error code, please click here for assistance.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
May 15, 2010 | Nintendo Wii Console
Ubuntu 8.10 - acer aspire one 150-Ab wireles not working
Ahhh, Ubuntu. You may need to go online and find wireless drivers that will work with your wireless card.
On an unrelated note, OpenSolaris has an option on it to download all of the compatible drivers for your computer when you first hardwire it to an internet connection, so if you keep having trouble with ubuntu, you could always try switching over to that.
Jul 05, 2009 | Acer Computer AOA150 Notebook
What do I need to conect my wireless encore router
you need to have a LAN card, but normally, all computers have built-in lan card provided its a new computer. make sure you also have a broadband connection
Apr 02, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
I have a wireles belkin router and the power light is on and the wireles light and the phone light and the internet light but i still cant get on to the internet with either my wireles laptop or though a...
go ahead and power everything down. wait a minute then plug in your router. once all the lights are steady power up your pc. once complete go to run, type cmd and enter. At the prompt type ipconfig and enter. ping your ip address.
Jun 01, 2008 | Belkin Computers & Internet
Compaq Presario Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
