Question about Hitachi VME545 Camcorder
Trying to copy camcorder tapes
I am trying to transfer video from camcorder to VHS from my Hitachi camcorder. Some of the tapes (recorded on a Sanyo camera in the 90's) transfers fine but some go into 'fast forward' mode and will not play normally. The material is precious kids stuff and I would dearly love to save it. Any idea how I can get it play properly? Some start off fine and then go into fast forward half way thorugh. Please help. Thank you.
  • Amanda Beaumont Mar 26, 2007
    Thank you for that Noggin. I'm afraid I'm not techy enough at the moment to transfer them myself but will look into getting them done eventually. I have about 20 8mm tapes though so would have to get them done a few at a time due to the expense. I would just like to find out why the 'fast forward' thing is happening on parts of the tapes. You can see and hear what is going on, only very fast like it's been taped in 'long play' and I am trying to play it on 'SP'. I will have a look tonight to see if it is an overheating problem, but I think it is more to do with the tapes. Would a studio be able to sort that out?
    I have just looked on Amazon.co.uk and the digital tranfer hardware you were talking about wasn't available in the UK?
    Again. many thanks for replying to my post.
  • 944 Answers
If you really value the material, then the best thing is to transfer it to a digital media rather than VHS. various digital media can be almost indestructible, whereas vhs tapes will eventually die, depending on the quality of the tape and the temperature / humidity in which they are stored. There are a few options for doing this. If you have a PC (or Mac) then there are numerous analog to digital video converting devices and software. First you need a video input/capture card in the computer, then software often comes with these. Otherwise windows movie maker, which I believe is bundled with windows XP service pack 2, apparently works for basic procedures. Have a look at this link - I haven't tried the item myself but it looks good for the money and has had good reviews; http://www.amazon.com/ADS-Tech-Video-Xpress-USBAV-191-EF/dp/B0009UDABW But there are many different ones. Another option is to use a professional studio to digitize your tapes - they are normally quite expensive because although the operation is not particularly complicated, it can be very time consuming. http://tech.yahoo.com/blogs/hughes/194 check this link for more ideas. As to the fast-forwarding issue, I have no real solution, but you should be able to edit this digitally easily enough. I suspect a fault with the camera, probably an overheating issue, but maybe as simple as a worn internal switch. tape faults are also a possibility. The age of the camcorder would suggest that it is probably not worth fixing, if you would like to try though please post again. My advice - go digital, get a studio to do it, use a good one and your footage will be preserved for ever in near perfect quality. The longer you leave it, the worse the tapes may become. else if you want to do it yourself, follow the first link and hunt around for other hardware - any problems please ask. Hope this helps :)
Posted on Mar 26, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 26, 2007
    Did you manage to try the tapes in another camera?
    if they work then the problem is with yours, maybe easiest to just try and borrow one to do your transfer.
    Hope you get some luck with your camera though from the other guys
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 27, 2007
    You're welcome
    please let us know what happens - someone else might have the same going on.
SOURCE:
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
I video taped a wedding and am trying to copy from my camcorder "VHSC" to VHS RECORDER - PROBLEM IS I AM GETTING AUDIO BUT NO VIDEO when i try to replay from vhs tape on VCR
I can only believe that you did not connect everything (the yellow video cable) correctly.
Tape to tape copies are normal and typical. Please consider retrying - and just do a few minutes of test video to confirm that it is working.
If you were doing a digital translation, I could understand a problem - but VHS to VHS should be a straight copy.....
Let us know how the test works. (BTW, I had a bad quality video cable - and had to replace it with another - which worked (and everything would display on my TV but would not copy onto another tape. My expert said that a copy protection thing in the record mode of the VHS recorder was the issue - ONLY a strong signal will be copied.
Oct 14, 2009 | Quasar VM-L153 VHS-C Camcorder
Toshiba d-vr600 record without viewing the whole tape
Unless both units has stated high speed transfer capabilities I think you have to do them one at a time and watch the entire video.
There are some units that are one unit for vhs to dvd. Panasonic is known to have some units but you are going to probably have to hunt for one. It will clearly state that it transferred compressed or highspeed.
Mar 02, 2009 | Toshiba D-VR4 DVD Recorder/VCR
How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
Jan 14, 2009 | JVC Everio GZ-MG20 Camcorder
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful http://www.allformp3.com/dvd-copy-software/convert-vhs-to-dvd.htm
Please rate me solve if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Lite On (ldw811s) DVD±RW Burner
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Hitachi VME545 Camcorder Logo
112 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
