Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
My canon sd300 will not turn on
I have triued new batteries, even tried to connect it to the computer it just wont turn on.
  • Anonymous Mar 22, 2009
    same here!
    Sniper:
  • 53 Answers
I had the same problem, and finally I took it to a camera repair shop and they said it was time to get a new one.
Posted on May 11, 2009
SOURCE:
Canon g7 dead wont turn on My Canon G7 wont turn on. I have tried new battery without succes. Please help [email protected]
That's a loose screw issue inside the G7 and the G9 that is common. The best place I know to get help for that one would be camerasandparts.com They just specialize in the powershots and they are awesome if you need help with one of these. Best of luck, they have your exact G7 no power problem right there on their site. I hope that helps.
May 27, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon SD300
No it won't charge through the USB port. Just buy a new generic charger for the NB-4L battery. They're very inexpensive. Here's some from Amazon:
http://www.amazon.com/s/qid=1217627331/ref=sr_st?keywords=nb-4l+charger&rs=172282&page=1&rh=n%3A172282%2Ck%3Anb-4l+charger&sort=price
Aug 01, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera will not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jun 03, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
My Canon PowerShot SD300 will not turn on even with a fresh battery.
Your camera sounds like it will need to be serviced by Canon.
You also may have the option of upgrading through their loyalty program for deep discounts.
Give the tech support a call and find out. If you are out of your one year warranty period, you will qualify!
May 29, 2008 | Canon Cameras
My Canon Power Shot SD300 will not turn on even with a fresh battery in it.
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon powershot sd 300
Most likely your flash bulb burned out or was damaged. If you feel comfortable opening your camera you can buy a flash module on the internet or ebay for around $20-$25 and install it yourself. If you do so, be VERY careful NOT TO TOUCH the capacitor as those things can store a massive amount of voltage even when the battery is removed and the camera has been off for some time.
If you don't feel comfortable opening your camera and trying to replace it yourself, my suggestion would be to get a new camera. Repairs by Canon usually run more than $100 and the SD300 is a bit old to be laying out that kind of dough, in my opinion.
Mar 12, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Powershot SD300 wont appear on computer
nothing on a sd300 but there is on a Ixus 40, see below for IXUS drivers and manuals http://software.canon-europe.com/products/0010105.asp
Sep 12, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Use as mass storage device
Connecting a camera to computer via a USB to download is one thing- Connecting a camera to Computer to feed back the the card is another. The chances are the firmware on the camera will not accept anything that is not in EXIF format. Try it -simply connect camera in the normal way. This will if you have the normal A C D drives will come up us removable storage -'E' with the appropriate icon in 'My computer' Now pick a file[s] and using the normal Edit/ Select/ Copy[Or right click] routine then go to the removable media['E?' right click paste See what you get- you wont break anything
Aug 25, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
