Question about Toshiba Qosmio G25-AV513 Notebook
Toshiba satellite L40-170 LAPTOP
I have the above laptop i dontseem to enable the touchpad, i have tried the f buttons and no joy any help please
My touchpad and control buttons on toshiba satellite pro c850-FJ don't work
Contact seller. I'm a bit confused? Brand new Windows 8 install then Uninstalled ? Why? Is Win 8 still installed?
Feb 11, 2013 | Toshiba Satellite E205-S1904 Laptop
How to enable touchpad on Toshiba Satellite L850?
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Oct 27, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Toshiba laptop touchpad not working
Most likely your problem is that the touchpad was disabled. Enabling/disabling could be done in two ways:
1. press Fn and F9
2. in control panel, mouse, you will find the option regarding enabling/disabling touchpad (in some machines called internal pointing device)
Aug 07, 2011 | Toshiba Satellite L655-S5101 Laptop
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
Touchpad is not working and does not show up in
You need to reinstall the Synaptics driver from Toshiba. If you do not have the Toshiba driver CD for your laptop you can try the generic ones from : http://www.synaptics.com/support/drivers
The touch pad may also be disabled in the system bios, (ie the options before you boot through to windows) Re enable it there if you are sure it is not a driver problem.
If still no joy, your local Toshiba agent can advise free on rectification, but you have to take the notebook in to them.
Hope this helps.
May 27, 2010 | Toshiba Satellite Pro M15-S405 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
1,263 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
