Question about Maytag Atlantis MDE6400AY Electric Dryer
Scraping sound on left side as it goes around
Maytag atlantis model MDE6400AYQ
Had the same problem. Opened and removed the front of cabinet, than lifted the top. One of the screws that mount the outer drum to the innner drum had come loose. The protruding screw was banging on the left side of dryer. Tighten and rechecked all screws (2 pairs of 2). Noise problem solved.
Posted on Apr 23, 2009
    Novelist:
    Scholar:
  • 95 Answers
You need to replace the tumbler guide rubber wheel. I would suggest to avoid further issues, replace all base guides.
It requires dismantling the Dryer.
e
Posted on Mar 02, 2009
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis model MDE7600AYW is making scraping noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsh4w2
Jun 23, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Im tryin to change from a three wire to a 4 on a maytag Atlantis. Saw some photos... But no luck I have the red on the right white in the middle black and green on the left. And it's not workin
Connect to three post terminal - black and red are interchangeable and belong on the right and left terminals. white goes to center, green goes to machine chasis not to any terminal post
Aug 04, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do i side vent my maytag atlantis electric dryer?
Attached is a link to a diagram of your dryer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170653
You would have to remove the back panel. Remove the existing vent pipe, install a 90 deg elbow of the same size diameter. Then cut a hole in the right or left side of the dryer cabinet that would line up with the new elbow.
Check the side cabnet of your dryer, it appears on the diagram that there may be a 4" knock out for a side exit vent.
Good luck, let me know.
Regards,
Jul 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Loud scraping sound
If it was put on a dolly from the back or dropped on the bottom the blower housing could be in contact with the drum as it goes around.
Apr 24, 2008 | Maytag MED9600S Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
