Question about Toshiba Qosmio F25-AV205 Notebook
Need to know why my windows installer does not work
Whe trying to install software, when it gets to the installation it says it will not allow installation that there is a problem. I have tried to go to the toshiba website to download windows installer , but cannot get access to any such software. Can anyone help me?????????
    President:
  • 1,073 Answers
Try to download windows installer from microsoft, ive seen this before a couple of times, sometimes it works by reinstaling windows installer...sometiimes not..if not you have to reinstall your OS again.
You will have access to download it from microsofr if you using a valieded copy of your OS
Good luck to you
Posted on Dec 17, 2008
Whe I start my pc a small window says the installer failed to exit a running instance of magic jack
I think magic jack relates to your sound driver/device. I would try removing and re-installing your sound driver. If you let me know your model of computer or sound card I may even be able to provide a download link for the drivers.
Mar 20, 2014 | Computers & Internet
Uninstalled the HP6300C series software since it no longer worked wirelessly. However, we cannot re-install the software. We have Windows 7 OS, the software indicates Xp and Vista. Could this be the...
Access the manufacturer's web-site: http://support.hp.com
Enter the model-number of the printer, and do the search.
Select Downloadable Device-Drivers.
Select Windows 7.
Download the device-driver.
Install it.
Jul 13, 2011 | Office Equipment & Supplies
Can not install old version of paper port on 64 bit system
I am assuming you are using one of the newer version of windows, although you don't mention this. There is a free version of paperport you can download over the internet so you might like to try this. With windows you can install 32 bit versions of software onto 64 bit system and they will generally work fine. You should also try using "compatibility" mode which windows uses to help manage programs designed for older version of windows. I have some older software that wont work on anything other than windows XP so I have installed a virtual machine onto my 64 bit computer, then installed windows xp onto the virtual machine, and then installed the software I need to use. This is a bit tedious and time consuming but works perfectly and allows me to use my older software.
Jun 20, 2017 | Brother DCP-9000 Copier
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
Microsoft Office small Business Edition 2003 keeps installing whe
try to uninstall the software and then clear the registries using a registry scanner then try to install the later version. If this dosnt work use an antivirus or a spyware remover
Feb 02, 2009 | Microsoft Office 2003 Small Business...
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Problem loading windows xp
try disabling legasy USB devices in bios
Jul 09, 2008 | ASUS K8V-MX Motherboard
Installing XP on P III 866 MHz pc
Hi Mri,
Download this software by clicking on this link.
http://www.killdisk.com/downloadfree.htm
Everything you need is on the site. Bottom line, this software will erase your drive & allow you to install Windows XP what every version. You can try installing you're current drive into another working system & you might be able to pull you're personal data off the drive. It's worth a shot. One way or another you're MBR & FAT system are out to lunch. It just happends.(Suprised you haven't received any blue screens)!
If I can be of more service, just post.
Let me know how thing go.
Good Luck!
Mike
May 03, 2008 | FIC FR33E Motherboard
Acer orbi cam not working
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Mar 07, 2008 | Acer TravelMate 3260-4874 Notebook
Error code 1606
To assist you requires knowing what software and if possible what version of the software you were installing. Some software is not compatible with Vista yet, some may never be and others already have made updates available -- part of the problem with your issue is determining where in that list of conditions your software falls. As well as possibly providing a link to a version of the software that claims to be installable on you machine.
You could also have the right software and an installation issue but that still requires knowing about the software that generated the error. If the message contained more than code 1606 the full text of the message would also be helpful.
Dec 17, 2007 | Microsoft Windows Vista Ultimate Edition
Toshiba Qosmio F25-AV205 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
