Question about Acer AC711B 17" CRT Monitor
No Image I have a Acer AC711 Monitor, when i switch it on only the power led is on but their is no display. i try to repair it by testing transistors, diodes and resistors but theses components is ok. Can you suggess me the main steps to troubleshoots this monitor or the possible electronic parts may be faulty? Thanks Eric
Your monitor cable mai have a broblem
Posted on May 25, 2008
  • 97 Answers
Typical failure is High voltage supply. Can you hear a high pitch whine or the relay click on and off? You will need some test point reffence voltages for the board and confirm you do not have a damaged VGA cable. It is not easy to give step by step via forum. Google "monitor repair", there were a couple good general guides that are printable. If youe high voltage tranformer (flyback) is gone, do not go any further. Price of a monitor flyback is $65 to over $100 depending on model.
Posted on Apr 10, 2007
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Screen turns off seconds after image is displayed
are using dvi cable is yoour out put on the cpu ok video out video card ect u test antehr screen on it test this one on differnt one if it bad its bad u cant usally get parts for these priotory
Feb 04, 2008 | Acer AL1916W 19" LCD Monitor
Black Screen - No image at all
Has to be a short some where in the monitor.
Mar 07, 2014 | Acer V193w LCD Monitor
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
The ON/OFF button blinks but no screen image
Since the power led button is on, I think the picture board on your monitor is faulty that is why it is not displaying anything.
Since your computer work perfectly with other monitor, it means the picture board is bad that is why it is not displaying any image.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Acer AL1716 F Monitor
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
How can solve the blurriness
I have the same problem nothing can be done. The monitor is not focused anymore.
May 25, 2009 | Acer AC711B 17" CRT Monitor
How to repair
MY SUGGESTION IS TO BUY A REPLACEMENT MONITOR AN LCD BECAUSE IT USES LESS energy about 50% less and at a low voltage.
YOU PROBABLY CAN FIND ANOTHER RELAY AND CAPACITOR ONLINE OR AT A TV REPAIR SHOP electronics supply warehouse BUT IF THESE COMPONENTS WENT BAD
OTHER COPONENTS MAY BE BAD ALSO AS A RESULT OF THESE HAVING FAILED SOMTIMES RESISTORS,DIODES AND TRASISITORS LOOK GOOD VISUALLY BUT ARE NOT.
Save your self sometime and money by getting a new lcd monitor
even if you repair your monitor its still old if you replace this mointor with a new one you elimiate all risk because a new monitor will have all new parts and a warranty and save money on your electric bill because it takes less power to operate.
Jan 16, 2008 | Acer AC711B 17" CRT Monitor
Acer AC711B 17" CRT Monitor Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
