Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Ethernet drive not spinning up.
When I installed it in a HD enclosure (USB), IE recognizes it, but says ''not formatted.'' Do I need a ethernet enclosure, if there is such a thing.
  • 22 Answers
You can always format it but if you have any data on it you will lost them
Posted on Dec 17, 2008
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Jumper settings to connect to mac
If the hdd is a 3 1/2" version you need a power supply to run it. The usb will only power a mini SATA 2 1/2 or smaller as the 3 1/2 needs 12volt supply as well.
Jul 02, 2017 | Western Digital Caviar WD1600BB 160 GB...
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other...
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Dec 30, 2010 | Fantom Titanium Hard Drive
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
After formatting my drive C: and re-installing my winXP OS, hardwares were detected (printer,mouse and keyboard), except for pc camera, external speaker and ethernet. PC cam was corrected after installing...
> my P5KPL-AM SE cd cannot be recognized by cdrom....
Huh? Open "My Computer". Is there an icon for the CD-ROM?
If you double-click that icon, does it "open" the files on the CD?
> Where can i get my drivers for ethernet???
From a computer WITH Internet access, access the web-site for the manufacturer of the motherboard, and download the network device-drivers to a USB memory-stick. Move the memory-stick to your computer, and install the device-driver.
Sep 26, 2010 | Computers & Internet
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Installed a 500G hard drive in the 3.5" enclosure. It doesn't recognize it as a hard drive. How do I fix?
Make sure that your HD was installed properly in enclosure. Remove the cable then atached again.
Aug 20, 2009 | Mad Dog Multimedia MegaVault USB 2.0...
Can't install XP
It could be bad RAM, but it could also be drive error.
Try running chckdsk.exe
If the drive is ok, try copying the win xp cd to the HD and try to install from the HD
First, you need to copy your Windows XP Setup CD contents to your harddrive. I recommend saving the xp install files/folders to a separate partition than where you're going to install xp to (ie. have setup files at d:\winxp\ and then install xp to c:\ drive)
restart your computer with the win 98 boot disk
at the command prompt change to the drive with the xp files
ie. cd d:\winxp\i386\
type winnt to start installing
install as usual
Dec 28, 2007 | ViewSonic Tablet PC V1100
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
