Question about Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ S616F Frozen dead at "Every moment has its music
  • 14 more comments
  • lil_young123 Jan 02, 2009
    When i try to charge it, it want charge to:
    F_I_N_T_C_H's Sony Walkman NWZ S616F Frozen dead at "Every moment has its music problem
  • jrobin16 Jan 02, 2009
    I have the same problem with my Sony MP3 player. It stays frozen on the "Every moment has its music" screen. I had just finished loading new music on it and unplugged it from the computer when this happened. Does anyone out there have a solution? I haven't been able to find one. Thanks so much for your help. I have had this just over a year and it's now out of warranty. This totally sucks!!
  • Anonymous Jan 03, 2009
    Identical problem. MP3 player is frozen. Reset button appears to turn off when pressed in, but then frozen screen returns. Looking at detail on My Computer all music in still on player (ie not reset), and selecting folder/files defaults and still plays music on media player. I have run the battery right down on player, then re charged and it goes back to frozen screen.
    Help gratefully received. Thanks. Pete
  • KathySt Jan 07, 2009
    Mine is a NW-A805. The problem is the same. What can I do?
    Please, help! Thanks in advance!
  • Anonymous Jan 25, 2009
    My Sony NWZ S616F went through a period of freezing, now it won't do anything. It won't reset or turn on or charge or even register as a piece of hardware when I plug it into my PC, it's just blank. I've only had it for 6 months or so, not over-used it, but bought it abroad, so it would cost me to send it off to be fixed. Just about to give up & buy a new one but any ideas for help would be gratefully received! Thanks.
  • Anonymous Feb 02, 2009
    Thanks XANAX...my problem is solved
  • Anonymous Feb 04, 2009
    My screen is frozen on the "Connecting USB" screen and when I let the battery die out,and i charge it back up,I still have a frozen screen.The reset button doesn't seem to do anything.Someone please help me!!
    mine is doing exactly the same
    ive had it less than 2 months and its already commited technological suicide
  • Anonymous Mar 15, 2009
    The screen is frozen completely with the "Every moment has its music" logo
  • Anonymous Mar 20, 2009
    my sony walkman is stuck on the every moment has its music screen i have tried pressing the reset button 3 times and it has not helped please help
  • pepstar Apr 14, 2009
    my sony nwz-s616f is stuck on the "every moment has its music" screen- when i connect to computer it wont let me delete any files saying they're corrupted or the directory isn't empty?
  • Anonymous May 09, 2009
    i plugged it in,sand the screen in blue and every time i press a button or plug it in again it doesn't help,?
  • Anonymous May 15, 2009
    my walkman
    my walkman won't charge and pressing the reset button doesn't do anything
  • atwhite84
    atwhite84 Oct 18, 2012
    I have the same problem but I've tried recharging it and reseting it. I shows that it's charging when i plug it in but that's it. It doesn't show in my computer. In device manager it shows up but with the little yellow triangle. It's says driver is up to date. When I do disable it and enable it it shows in my computer but theres nothing in it.
  • udit kumar May 30, 2013
    when i press reset button o my sony ipod nwz_b172f for 1 minute but its not work to fix boot error problem pls help....
Find a needle and press the reset button at the bottom by it.I havesolved thesame problem by this way.
Posted on Jan 13, 2009
  • 6 more comments
  • nicoledianeg Oct 29, 2010
    nope it wont work for me :/
  • wandawhit Nov 22, 2010
    I had to press it 3-4 times before it worked. You can kind of feel it click when you press it hard enough. I thought I was going to have to buy another mp3. THANKS XANAX!!!!!!
  • essam31001 Feb 25, 2011
    press the reset button by pin and Wait. Needed to be a black screen for .1 Minutes .
    xanan Thanks .
    Sorry for my language is not good. I wanted to join
    hold reset on the button for 1 Minute
    Thanks XANAX
    i press reset button for 1 minute but its not work to fix boot error problem pls help.....
  • Dave Jun 09, 2013
    I just got off the web chat with Sony after almost an hour. The person kept asking the same questions over and over and just said to stick a paperclip in the hole. That's it. I tried it and nothing happened. then the person suggested holding the paperclip for longer. they said there is a customer support phone number 888-222-7669. I will never get a Sony Walkman again. Just a huge waste of money and they go on the fritz right after the warranty period is up.
  • johnny bagwashi Aug 18, 2013
    just done my nwz 163 by putting a small screwdriver in the reset hole i didnt even know there was a reset on it.
  • Nhat Le Thien
    Nhat Le Thien Dec 20, 2014
    I just had the same problem, Can you help me with this? @XANAX
  • 3 Answers
Yeah i just had the same problem and if you connect it to the usb and then push the reset button its gonna turn off then its gonna say low battery please charge. it worked for me so...
Posted on Feb 05, 2009
  • Dave Jun 09, 2013
    This did nothing. Any other suggestions please?
My Sony Walkmann NWZ-E436F was stuck with the same message as the posts mentioned. I had just copied a large video file to it and had unplugged the USB cable from my PC. I tried restarting it and pressing the reset button on the back but same thing stuck at that message.
I plugged the Walkman back into my PC and opened up a Windows Explorer windows. I clicked on WALKMAN to find the big file I added. Then, I deleted it. For good measure I deleted another big video file as well. I still had 1.88GB of space left before doing this so I'm pretty sure the flash wasn't full. I unplugged the USB cable and "cha ching" it bootup up like normal.
I believe the video file got corrupted somehow and was causing the Walkman to freeze up when trying to start.
I hope this works for some of you.
Posted on Jan 16, 2009
I connected my walkman to the computer overnight (you might not have to charge it overnight but do connect it so it charges) then reconnect the walkman to the computer so that the blue screen comes up. Then the loading thing(the thing that runs across the screen towards the right) is gonna show up. As soon as that shows up press and hold the back/home and the option/power off buttons until it turns on. Hope this helps :) mine has been like that for a year and i just fixed it today.
Posted on Jul 25, 2010
  • Dave Jun 09, 2013
    It was not working for a year? Did you have to let the battery go dead first?
  • Dave Jun 09, 2013
I had the same problem and the reset button didn't clear it. I did find a solution:
1) download the version 1.01 Firmware from
http://esupport.sony.com/US/perl/model-home.pl?mdl=NWZS616F&LOC=3
and install according to their instructions. I over-wrote v1.01 with v1.01 and didn't have any problems.
This cleared the blue screen but I had a new problem in that it only showed I had 400mb of space even though there were no files. I then
2) went into the setup menu and re-formatted the drive.
3) I reloaded the music from the hard drive.
You may or may not need all these steps but it worked for me. I got tired of waiting for sony-support to answer and started trying whatever I could think of.
Buena suerte
Posted on Feb 18, 2010
    New Friend:
I have the blue ring that says "connected to USB. The player cannot be operated." I was loading music and videos and I guess tried to do something too quickly.
Usually when I disconnected the USB cord, it would work fine. Now it is dead and useless. None of the suggestions above have worked so far. I've tried replugging it it in. Nothing. I tried connecting it again to the laptop and checking printers and hardware and going to the Sony Walkman screen. Nothing. It just says there's an error and to try reinstalling driver. Tried that. Nothing.
Now it won't play, can't be reset, does nothing when plugged in.
Should I wait for it to go dead and then plug it in again?
Will Sony do anything to help? Do they have a phone number I can call or is this Sony Walkman just an overpriced piece of trash?
Posted on Jun 09, 2013
I did press the reset button but it shut down and now i can't charge it or turn it on
Posted on Aug 19, 2010
Push start button for 4 to 6 minutes untill the loading screen not turn off...then push reset button ...then attach the player into computer usb..and after 5 minutes it shows in my computer..
Posted on Aug 06, 2010
    New Friend:
I have had my walkman for over a year and its stuck saying charge the battery i tried but it wont charge with my usb but i says its pluged in ...my laptop dose not see it and before this it was stuck on the every moment has its music screen what should i do please help!
Posted on Dec 23, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: NWZ-S615FBLK sony
On the very bottom of your MP3 player, next to where you'd plug the USB in (on the left of the plug) is the reset button. Hit that with a pin, and it'll reset =D
Posted on Oct 02, 2008
SOURCE: remove write protection on a walkman nwz-s616f
I gave up***,could not get any free Advise
Posted on Nov 13, 2008
webmaster21
  • 803 Answers
SOURCE: Describe your Sony Walkman Video NWZ-S616F MP3
Hold the reset button on the back and it will rebot and should work.
Posted on Sep 24, 2009
Tip
Download DVDs to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/...
Run into fantastic background music on DVD Movies YouTube, MySpace, MSN video, and wanna enjoy the background music on your Sony Walkman? Wanna enjoy DVD movie on Sony Walkman but don’t know how to rip DVD to Walkman? This article will show you how to convert video to Sony Walkman, how to rip DVD to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/ NWZ-S738F, 8GB) for your watching.
The leading role of this article is Daniusoft Video Converter Suite which is an applied Sony walkman video converter, it is already optimized for output setting for Sony Walkman video (*MPEG-4)/Audio(*MP3) in its profile. Very easy to use, like the follow illustration:
Okay, without further ado, let’s cut to the point to get things work.
First of all, Download Daniusoft Video Converter Suite, after installing it, you will get 2 apps: DVD Ripper and Video Converter.
Next, run Daniusoft DVD Ripper software to convert DVD to Walkman-friendly format: MPEG-4. The nifty walkman DVD converter has all essential functions such output profiles, parameter settings and video editing. The detailed conversion process is showed as below:
1. Click 'Load DVD' button to add the DVD file. You can also click 'Load File' to add DVD/IFO from your hard disk. (Ensure that you have sufficient space on hard drive to store the DVD).
2. Select profile "Sony Walkman -> Walkman Video (*.MP4)".
P.S. If you wanna extract background music from DVDs and convert to Sony walkman, Just Select profile "Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)".
3. Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click "Edit" to adjust effect, length, size and watermark, etc.
5. Click "Start" to convert DVD to Sony Walkman.
Using Daniusoft Video file Converter to extract background songs from YouTube, MySpace, MSN video to Sony Walkman is as easy as Daniusoft DVD Ripper.
1. Run Daniusoft walkman Video Converter and load your video downloaded from YouTube, MySpace, MSN, etc.
2. Select profile "Convert to -> Common Audio -> MP3-MPEG Layer-3 audio (*.MP3)".
P.S. If you wanna convert your favorite web-video files from YouTube, MySpace, Facebook, MSN etc. to Sony walkman, Just Select profile "Sony Walkman -> Walkman Video (*.MP4)".
3.Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
5. Click "Start" to convert video to Sony Walkman.
Now, you can connect Sony walkman to computer and copy these converted DVD video or background music to your Sony walkman (NWZ-S618F/NWZ-A818/NWZ-S616F/NWZ-S738F) player. Using the Daniusoft walkman video converter well can cover the boring journey on a bus or a plain with myriad happiness and fun.
on Mar 29, 2010 | Cell Phones
My mp3 is frozen
Press the reset button on the bottom with a toothpick
Jan 30, 2010 | Sony Walkman NWZ-S616F MP3 Player
Sony mp3 player model no.NWZ S616F - screen frozen
let the battery run out and charge it completly and re-boot it
May 15, 2009 | Sony Walkman NWZ-S616F MP3 Player
Frozen
From the home menu go to settings then music settings then new song pop up then select off.
Feb 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-S616F Wet?
luck is everything hopeful you dryed it immediatly and if it was sticky you need to open it up and try wipe it clean and remove moisture
Jan 23, 2009 | Sony Walkman NWZ-S616F MP3 Player
hit the reset button with something sharp at the bottom of the walkman
Nov 24, 2008 | Sony Walkman NWZ-S616F MP3 Player
LIBRARY ERROR
check that the file you are using is formatted for the walkman ....ie mp3 ...
also for 2nd one...open walkman folder when connected to usb and add the music/video folde as required
Oct 04, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
18,149 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
