Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba HM 167/117 Series 65in Television will not turn on!
The on button the side of the television does not work. Tried using the remote but that did not work either. The television does receive some sort of signal because the yellow lights at the lower part of the tv blink. If it were to turn on, the blue light would come up and stay solid. I don't know if its a blown fuse or not, but this problem has only come up recently for the first time. Ive also tried using a different remote but that does not work either. Any help would be appreciated. Thank you!!
Happy Holidays,
Mike
SOURCE: TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv on....tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Erick
Posted on Jul 14, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
My toshiba 65in will not respond to my remote
The infrared sensor to your TV might be bad. It should be replaced. It is an easy to get part, and is cheap to buy from any electronic spare part shops. To access and replace it, you have to pull out the front panel PCB. In fact, you have to open the TV to replace it. The component will look somewhat like this.
9_25_2012_12_43_33_pm.jpg9_25_2012_12_43_54_pm.jpg9_25_2012_12_44_12_pm.jpg9_25_2012_12_44_46_pm.jpg
Sep 24, 2012 | Toshiba 32AF43 32" TV
How can I program my remote to a Toshiba 60"?
Here are the codes for you Toshiba TV: 631, 617, 635, 744, 615, 667, 590, or 688.
I have provide instructions on how to program your remote to your TV.
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 18, 2011 | DISH Network 135899 Remote Control
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
65in toshiba heard a pop then screen went blank what could be the problem?
reggie6205,
Blown lamp. See my tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv for help with this.
Thanks for using FixYa and for the great rating.
hardrocko
Jul 15, 2011 | Toshiba 65HM167 65" Projection Television
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
What are the codes for a toshiba tv?
  • 1
  • 2
    Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
  • 3
  • 4
  • 5
  • Mar 09, 2011 | Toshiba Televison & Video
    I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
    Try the following procedure:
    1. Make sure there are working batteries in the Toshiba remote control.
    2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
    3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
    4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
    5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
    Feb 28, 2011 | Toshiba Vc-260 Remote Control
    Toshiba rear projection tv 1996 cinama series
    Ur power inverter board is dead.
    U need a new one.
    Aug 29, 2009 | Toshiba 50H82 50" Rear Projection...
    Can't find Comcast remote code for Magnavox television 15MF605/17
    Not every remote will control every TV. You basically have 3 options. 1) Call Comcast and see if they have additional codes not listed on their website/documentation 2) Call Magnavox and see if they have additional codes that might work with your remote. 3) Buy a 3rd party remote that works with both your comcast box and your television.
    Jun 03, 2009 | Philips Magnavox Learning Universal Remote
    Toshiba Cinema Series
    possible regulator ic. in the power supply.
    Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
    Toshiba 65HX81 65" Rear Projection Television Logo
    354 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
