Question about Symphonic WF803 DVD Player/VCR
How to hookup dvd.vcr to tv
I need help hooking up a dvd/vcr combo to my tv
  • 3 more comments
  • lisadoodles Dec 20, 2007
    my tv has the connector that has the gold wire, that screws on, and the back of the dvd/vcr combo has the type that just pushes in.
  • Anonymous Feb 07, 2008
    There is no place on the VCR/DVD to plug in the Basic cable. This is the 3rd unit I have tried. I have a Sanyo and it works fine. Can't find a new one so bought a Phillips. Getting very discouraged. Please help!
  • HawkeyeJ79 May 18, 2008
    hooking up sanyo dtv to my dvd/vcp player. i can get the dvd to work an audio 4 the vcp to work but no picture for the vcp any ideas
  • Anonymous Jan 04, 2009
    There is no place on the VCR/DVD to plug in the Basic cable on my magnavox vcr/dvd and my Memorex tv
  • leo Finn
    leo Finn Feb 07, 2009
    Does the Symphonic WF803 DVD Player / VCR Combo have a digital tuner, or will I need a converter box to watch my analog TV via antenna?
    Genius:
  • 1,074 Answers
First of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from antenna.you connect another from the out to tv to the tuner connnection of your tv.and you are on.to connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
Posted on Mar 26, 2007
SOURCE:
How do I hook up this vcr/dvd combo? Tv has two
Yes you need a modulator. The one I used to hook up my Mother's VCR/DVD Combo only cost $15 at Walmart. It was a RCA brand.
Jan 19, 2010 | Philips Magnavox DVD/VCR Dual Player
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
Jan 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
HOoking up DVD/VCR without correct connectors
either use an old vcr to act as a signal converter or go buy an "rf converter" from an electronics store to change composite audio/video signal to channels 3 or 4 and that should do the trick.
Dec 26, 2007 | Sansui COM311AD 13 in. Combo
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
563 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
