Question about HP OfficeJet 4215 All-In-One InkJet Printer
Printer (HP 4215) wiggin out on me
So I installed new ink cartridges and now the little sliding gizmo that they fit into won't slide back in once the door is shut, it's like having a seizure in there. I don't know what I did but darn it I hope it can be fixed. Anyone have any ideas? Thanks!
Um realized it was really broken when a small, obviously broken, piece fell out when I lifted the printer up. So off to Costco to get a new one...
Posted on Dec 18, 2008
How to install and ink cartridge on a hp laserjet 3200 printer
Hi Kristin,
Open the printer door by pressing the two door latches.The cartridge is in a slot with its handle facing you.Take the cartridges handle and pull out the cartridge from the printer.Take the cartridge and shake a little bit to evenly distribute the ink.Hold the cartridge by the handle with the arrows facing the printer and slide it back into the printer.Make sure its properly seated into the black grooves.Close the printer and paper paths doors firmly.
Hope this helps.Thanks!
Please rate this answer.
Nov 26, 2011 | HP LaserJet 3200 All-In-One Printer
Bought used Photosmart C3180 printer. Need to know how to insertcartridges. Thanks
for this particular printer, there are two slots, one with a green triangle and another with 2 different shapes. The left one is for colour and the right for black ink.
First you want to pull the desired cartridge out by putting a finger on both top and bottom and it should literally slide out (if it doesn't first time lift it up slightly first). Save the cartridge for future refill and the cartridge you want to put in you hold the same way and again from the bottom just literally slide it in. You should be able to click it in once it is all the way - this indicates it is in correctly, the printer should now run a test print
May 24, 2011 | HP Photosmart C3180 All-In-One InkJet...
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    How do you place cartrige in printer
    Step eight: Install the cartridges
    1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
    2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
    3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
      • Slide the tri-color cartridge into the left slot.
      • Slide the black or photo cartridge into the right slot.
      Figure 7: Insert the cartridgec00830211.jpg
    4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
    Aug 08, 2010 | HP Officejet 5780 Printer
    How to change the ink toner for clp 310 n
    open fron door and slide cartridges out, slide new cartridges in, just remove protective tabs from new cartridges and that is all...
    Jul 22, 2010 | Samsung CLP 315 Laser Printer
    How to install ink cartridge for hp640 fax
    open the front panel door and take out the ink cartridge by sliding it downwards and then pulling it towards yourself. in order to put the cartridge inside the printer you need to insert the same by sliding it from top to bottom and once you hear a click sound it means the cartridge has been installed
    May 21, 2010 | HP 640 Inkjet Fax Machine
    How do I put new cartridge in
    Follow this procedure to install print cartridges in you printer.
    1 Turn on the HP Officejet, and then lift open the print-carriage access door.
    The print carriage moves into view.
    2 After the carriage stops moving, push down on the top of the print
    cartridge to release it, and then pull it toward you out of its slot.
    3 Remove the new print cartridge from its packaging and, being careful to
    touch only the black plastic, gently remove the tape by using the pink pull tab.
    Caution! Do not touch the gold-colored contacts or ink nozzles.
    Once you have removed the plastic tape, install the print cartridge
    immediately to prevent the ink from drying in the nozzles.
    4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
    Press firmly until the print cartridge snaps into place.
    Caution! Do not attempt to push the cartridge straight into the slot.
    It must slide in at a upward slight angle.
    5 Hold the tri-color print cartridge with the HP label on top. Slide the print
    cartridge at a slight angle into the left side of the print carriage.
    It must slide in at a slight upward angle.
    Note: You must install both print cartridges in order for your HP Officejet to work.
    6 Close the print-carriage access door.
    “Press OK to print Align page” appears on the display.
    7 Press OK.
    Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
    INK CARTRIDGE WILL NOT FIT BACK INTO THE PRINTER
    The white roller is the hub that engages with the toner cartridge after it is installed. It is flush with the toner door open. As the door is closed the white arm attached to the toner door on the right side causes it to move inward. One possible scenario is that the tab on the door that it clips to is broken or the clips on the arm are damaged.
    Nov 12, 2008 | HP LaserJet 2420 Printer
    Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
    Dear customer,
    The most common solution is to follow the steps as follows
    1. unplug the power cord
    2. press and hold down the <ON/OFF> button and reconnect the power cord
    3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
    4. Display LED show "0" press the <+> button 1 time Display LED show "1"
    5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
    6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
    7. Push down on the end of the black cartridge. A clicking noise will be heard.
    8. Slide the cartridge out of the holder towards you.
    9. Push down on the end of the color cartridge. A clicking noise will be heard.
    10. Slide the cartridge out of the holder towards you.
    11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
    12. Reconnect the power cord.
    13. Turn on the printer.
    14. Open the cover. The carriage that holds the ink will move to the left hand side.
    15. Place the black cartridge in the bottom of the printer.
    16. Slide the black cartridge back until is cannot go back any further.
    17. Push up on the end of the black cartridge, a clicking noise should
    be heard.
    18. Place the color cartridge in the bottom of the printer.
    19 Slide the color cartridge back until is cannot go back any further.
    20. Push up on the end of the color cartridge, a clicking noise should
    be heard.
    hope its udeful. thank you.
    Jul 09, 2008 | Office Equipment & Supplies
    My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
    It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
    You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
    Have more questions? Please feel free to ask.
    Hope this has helped.
    Luck!
    Mike
    May 12, 2008 | Office Equipment & Supplies
    HP OfficeJet 4215 All-In-One InkJet Printer Logo
    52 people viewed this question
    Clive
    Clive
