Question about Acer Aspire 5100 Notebook
My acer orbicam just suddenly stopped working. I can't use it in messenger either. It says there is an update for orbicam, it takes me to the acer website, but i can't seem to find what i need or do not know what i'm looking for.
  • 1diarmuid Dec 22, 2008
    cammera just stoped workig
My orbi cam says it stop working properly and needs update are there free downloads for this function
Sometimes the acer orbicam software will stop working if you have pictures saved in the "my pictures" folder.
Yes this is very weird, but I have seen it happen.
if you need updates for the orbicam software:
www.acerpanam.com
Jan 14, 2010 | Acer Aspire 5100 Notebook
Aspire 5610-2762 Orbicam not working
Ready for this, goto to start>my pictures and remove all images from that folder except for the samples folder, just create another folder in your documents for these images.
Now start the webcam up again.
Sounds stupid but it works.
Cheers
Jun 16, 2008 | Acer Aspire 3680 Laptop
plz try by reloading the webcam software if you have webcam
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
mine is a acer 9300 and my can just says"acer orbi cam stopped working::what is wrong with these computers,its been used 3 times_?__and crashed__??
Feb 09, 2008 | Acer Aspire 3690-2196 Notebook
Acer orbicam has stopped working
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Jan 28, 2008 | Acer Aspire 5100 Notebook
sounds like youre using vista where live messenger starts up auto and tries to log you on whether you use it or not .if so let it run its course then right click on the icon and disable then reboot
Jan 10, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
