2000 Pontiac Sunfire Logo
Posted on Aug 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuse panel diagram - 2000 Pontiac Sunfire
Randy Handy
Level 3:
  • Master 496 Answers
  • Posted on Aug 10, 2012
Randy Handy
Master
Level 3:
Answers
496
Questions
Helped
248879
Points
1752
Fuses
Print
REPLACEMENT
See Figures 1, 2, 3, 4, 5, 6 and 7
Fig. Fig. 1: The power distribution box in the engine compartment contains fuses and relays
Fig. Figfuse panel diagram - 0900c1528003cffb.jpgr for the interior fuse panel
Fig. Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses
Fig. Fig. 5: There are generally four types of fuses used in these vehicles
Fig. Fig. 6: Fuse current rating and color code chart
0900c1528003cfff.jpg fuse panel diagram - enlarge_icon.gifwww.autozone.com/autozone/repairinfo/repairguide/repaifuse panel diagram - enlarge_tooltip.gifc=http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/03/cf/ff/medium/0900c1528003cfff.&imageType=gif&imageName=Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made">enlarge_icon.gifenlarge_tooltip.gif
Fig. Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is easier to say than to do. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution.
Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement.
Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute.
A blown fuse can easily be checked by visual inspection or by continuity checking.
The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
REPLACEMENT
  1. Locate the fuse for the circuit in question.
When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  1. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  2. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse
2answers
1996 Ford Taurus GL 3.0 - V6. Is there a diagram of the distribution fuse box for it please?
copy and paste
https://fuse-box.info/ford/ford-taurus-1996-1999-fuses-and-relay
Fuse box panel diagram 88 Cadillac brougham. I need a picture and information on where and what fuses go into the fuse panel in a 1988 cadillac brougham d elegance v8 5.0 307
The fuse panel diagram is in the owners manual. If no manual is available, type into your browser your "vehicle year and make" and "fuse box diagram" it will direct you to a page of different diagrams. Find the one that meets your needs.
1999 chevy express fuse panel diagram
Go to www.bbbind.com free wiring diagrams an TSB'S ! On the home page click on technical information , five box's will pop up . Click on
Technical Service Bulletins & Wiring Diagrams
All TSB's and diagrams for every make and model - FREE
next page go to the bottom an click on I agree ! Next page click on wiring diagrams an enter your vehicle info. System - Electrical distribution . Subsystem - Fuse panel . Here you go Jerry hope this helps you !
ne
25helpful
Fuse panel diagram for 1990 ford bronco 2
Here's the diagram for the fuse panel under the dash. There is also a fuse panel under the hood next to the air filter.e589aae.jpg
1helpful
Where can find a fuse panel diagram for a 1986
You should be able to find a fuse panel diagram in the back of any repair manual(Haynes) which you can get at any auto parts store. The fuse panel in the glove box is for your fan and air conditioning. The other fuse panels are general. Your truck should be a 22r carborated motor unless altered.
63helpful
5answers
Fuse box diagram
For Ford's fuse diagrams and schemes you may want to check Ford diagrams schemes imgVEHICLE com
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
