Question about Sceptre X37sv-Naga 37 in. LCD Television
No power. The technician says it is a "bad hi voltage inverter". He says he has no source for this part. Sceptre says they sell a "power board" ($285+s&h).Does anyone know if a hi voltage inverter is part of the "power board" that Sceptre sells?
My 3 year Sceptre 27" died. Local TV tech said it was the power module. Charged $25 for the diagnosis and wanted $190 to fix it. Took it home, popped the screws and the module almost fell out. It's a simple plug'n'play!!! Found a new module on eBay for $65 shipping included.
Posted on Dec 30, 2008
SOURCE:
Why isnt it turning on. only the blue light turns on and then i try to turn it off and the rede light comes on. when the red light comes on it makes a hogh pitch sound?
More likely to be unstable DC voltages in the power supply due to bad DC filter caps, unplug it so it will not do more damages to the circuits.
See the 17" version here with bad caps:
http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 02, 2011 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
My x42 screen turns blue for a few seconds and then from the bottom of the display it quickly blanks. You can still hear the sound but the picture remains blank. I have tried to change sources but it...
The problem can be bad backlight inverter board or it is not getting the 24vdc from the power supply. Look inside to see if it has bad caps with bulging tops. Also check the power supply output voltages, you should have 5vdc, 12vdc, and 24vdc.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sceptre+X42GV-Naga&stock=all
Jan 05, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
Black screen
could it be a dry solder around the inverter transformer , try to re solder all suspicious points , that should fix the problem, hope it helps , AJ
Jun 04, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
X9g komodo v screen just turned blank (white)
Go to ebay, type X9g kimidi logic board. Usually, some seller might have pulled working parts from other monitors and sell them individually. If you cannot find them, google "buy x9g komodo logic board". Some website, I'm quite sure will sell them.
Mar 17, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Monitor Powers off after a second or two.........
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
Sceptre DCLCD19+ MONITOR WHITE SCREEN
To me it sounds like the bulb is having a problem with powering up. It may be an issue with the power adaptor or the outlet it is plugged into. Have you tried to plug it in, in other outlets?
Dec 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Flashing green power indicator lamp.
Check out the data plug- you may have bent some pins.
May 31, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X37sv-Naga 37 in. LCD Television Logo
706 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
