Question about Motorola Mobility RAZR V3
Time how to remove the time off your front screen and leave it on the main screen
    Brigadier General:
  • 7,752 Answers
Sorry that is not possible on the v3
Posted on Dec 26, 2008
Were is cmos battery located
removing cmos battery doesnt work no matter how long you leave cmos battery out been there done that , you have to locate cmos jumper on motherboard , remove main battery & memory cards , peel back clearish foil on motherboard near where memory cards install , should see jumper points on motherboard , take bread tie touch jumper contact leave main battery out stand up like book plug in power adapter , and turn on only until boot screen then shut-off , install memory card , remove jumper and try starting laptop , if it hasnt cleared password , remove memory cards and try jumping it again
Mar 07, 2014 | Acer 4220-2346 Notebook
My olimpia spledid piu Air Conditioner is flashing 8 on the display screen, it wont turn on at all. Anyone know what it means or how to fix it
In our case this error means that the grandkids have jammed jigsaw puzzle pieces in the main blower at the front. The manual says to return to service centre for repair. If you've got a philips head screwdriver, you can fix it yourself. First REMOVE POWER CORD FROM WALL. Remove back cover, undo 7 phillips head screws, note the bottom 2 are longer for assembly. Remove front cover by undoing 3 screws on each side. Be careful with fine ribbon cable you can unplug it at the connector on the unit. Remove whatever has jammed the main blower, in our case it was jigsaw puzzle pieces, that could not be seen when the unit was assembled. Replace front cover, don't forget the ribbon cable. The front cover sort of goes back on from the bottom front first, and is snug over the top. Replace back cover, (remove dust from internal radiator fins first). Leave turned off for an hour or so if you had the unit upside down to remove blockage. Boom you just saved yourself a couple of hundred bucks probably.
Jan 03, 2012 | Heating & Cooling
I cannot read the digital screen on my Gaggia Titanium coffee machine. One comment said to remove the top of the machine & follow ribbon cable to the main board. Is that accomplished by removing the...
Hi. Thats where the screen is, in the front panel, your heading in the right direction. I repair them all the time and usually on them,some water has leaked onto the board which blew. Look around for leaks and drips. Should really be done by a technician. Sometimes more than one board is faulty. Daz
Aug 14, 2011 | Gaggia Titanium Espresso Machine
Front screen and main screen are blank white.
When this happens it can be caused from a couple of things; I would recommend that you hard shock the device. You can do this by removing the battery while the device is powered on, leave it out for a minute, then reinstall the battery, and power the handset up. If this does not resolve your issue, then you are looking at a more serious handset issue.
Mar 08, 2011 | LG VX5500 Cell Phone
My washer leaves streaks on my white clothes.
Likely the main bearing is beginning to fail.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore Elite 45986 Front Load Washer
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Affinity Front loader
Its normal for water to collect in the seal folds. The main thing is to dry it out completely. Take a dry cloth or sponge and try to remove excess water. Leave the door open to dry it out. You can even use a de-mould agent spray (many varieties available in the market). The main idea is to kepp the folds dry.
Hope that helps!
Sep 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE 9t quiet pak
Sounds to me like the Main Computer has failed. F11 means it is not communicating with the Motor control Board. It has nothing to do with the door locks. Remove to lid of the machine to axcess Main control. Sometimes a tap or two on the board makes them work again for a short time. Leave unit powered down for a few mins to reset board.
Nov 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Permanent blue screen display
I had the frozen blue screen twice. As a cowboy reset, I removed the battery for a minute, then put it back in. Worked for me, didn't erase my contacts or anything.
Oct 22, 2007 | LG VX5200 Cellular Phone
Motorola Z3
Try checking the time settings:
Settings > Initial Setup > Time & Date
If it is already on Auto update, then try turning it off, perhaps your area time clock it sync's with is screwy and unreliable
Also a note about alarms, I have noticed if you leave your phone slider not on the main screen (closed/off etc) then alarm will not sound
So after those late night calls, make sure to close it and leave it on the main screen.
Aug 23, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility RAZR V3 Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
