Question about Dell E193FP 19" Flat Panel LCD Monitor
Just rebuilt new pc
I have a dell 2.8ghz...put in a new hard drive...and connected everything...my lcd now says power save mode...so i cant see anything to reinstall os..what do i do?
  • stephar84 Dec 17, 2008
    how do i do that?
    President:
  • 1,073 Answers
Dont connect the monitor via your graphic card, its not installed yet. Connect your minitor via the motherboard.
Good luck to you
Posted on Dec 17, 2008
  • Nicolas
    Nicolas Dec 17, 2008
    you do that by using the vga port on your mobo
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
My new Dell flat screen monitor is blank and posting a message - entering power save mode- ... when I restart it briefly displays the Dell logo and other normal display at normal startup then switches to...
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Jun 07, 2009 | Dell E193FP 19" Flat Panel LCD Monitor
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
I have a Dell Inspiron 530
I have a Dell Inspiron 530S, and it exhibited the same symptoms as rguggemos's & Wilburollie's.
I can put it to sleep, but when I try to wake it, it won't. The screen will stay black. I can hear the drives spin up, and the fans go on FULL blast, and the blue power LED stays flashing, but the computer will stay like that - no picture or anything. Then I'd have to press & hold the power button to force it off, then power back on. Not ideal.
The solution that worked for me?! On boot, at the "DELL" logo, hit F2 to enter the BIOS setup, go to Power Management, and change the standby mode from S3 to S1. The difference? S3 is a "deeper" sleep, w/ more components powered off, which is better, energy-wise, but it is more difficult to wake from. S1 is a "light" sleep. Give it a shot! Maybe it'll work!
- Mike
Stolen from another forum:
S0 (Working) is lit. The CPU functions in entirety; the conservation of power is on a basis of by-device.
S1 (Sleep). The CPU is stopped; The RAM is regenerated; the system functions in reduced power.
S2 (Sleep 2) The CPU does not have any power; The RAM is regenerated; the system is in lower mode of the S1.
S3 (Standby) The CPU does not have any power; The RAM regenerates at minimum; the power supply unit is in mode of reduced power. This mode is also called “Save to RAM”.
S4 (Hibernate). All is powered off, but the memory was saved like temporary file on the hard drive. This mode is called “Save to disk”.
S5 (Off) Everything is shutdown. Means you need a full reboot.
Dec 11, 2008 | HP Media Center m7060n PC Desktop
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My desktop pc has gone into power save mode
Turn the whole pc off then back on. If the LCD stays in power save then I would try a diffrent monitor on the PC. If that fixes it the the monitor is probably stuck in power save. Check www.lcdrpair.us for parts and instructions.
May 28, 2008 | Dell E173FP 17" LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
71 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
