Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Need to know how to change lid switch on whirpool model lsq9544kq
Any ideas, schematics etc thanks
2 Suggested Answers
get-it-goin
  • 85 Answers
SOURCE: I need to change the switch of a washing machine,
hi there.remove the screws at the rear of the lid,then push the lid backwards,from the front.its held on by pegs that lock into the lid.hope this helps,steve
Posted on Apr 19, 2009
How much is a lid switch for a whirpool washer
Depending on model there not much, I usually hot wire mine..just take the switch off and connect the wires together with a wire nut...
Apr 03, 2014 | Whirlpool Whirpool 3.5cu ft Top Load...
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The screws that hold the lid switch loosened all the way, and will not tighten back up. How do I open the machine to secure the lid switch? Thank You - Km
Welcome to FixYa.
Based on your description, "the screws that hold the lid switch loosened all the way, and will not tighten back up"
it sounds like you`ll need to replace the lid switch, but first...
( this is also based on the idea its a whirlpool made top load, but you haven`t specified )
This is a common problem with these type of units since the assembly is made of plastic, fortunately changing it is pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Sep 16, 2010 | Washing Machines
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
Need to replace lid switch.. How do i get to the switch
The following link explains the steps required to replace a lid switch:
Your washer is manufactured by Whirpool, so these procedures do apply. If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Aug 06, 2009 | Roper RAX4233PQ Top Load Washer
I have an whirpool (LXR6232EQ0) washer. The agitator does not move after the water fills the tank. Also on the rinse cycle, the agitator does not spin. Any idea would be appreciated...
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 17, 2009 | Whirlpool LXR6432JQ Top Load Washer
I need to change the switch of a washing machine, cannot open the lid (whirpool)
Apr 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin unless you lift lid. LSR5132PQ
You need the lid switch adjusted or replaced. Easy and inexpensive. With the correct model # I can get you schematic and part #s. Dave www.washermd.com
Dec 13, 2008 | Whirlpool LSR5132PQ Top Load Washer
Maytag lat8426aae
need a picture of the schematic or better yet scan it.
w/o seing the scheatic can't help you!
Oct 11, 2008 | Washing Machines
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
