Question about Nortel Networks BSGX4e Business Services Gateway Router
Voicemail How did you reset the password? We have tried everything, and the customer service at Nortel is anything but. Please if you have figured it out we would appreciate it if you would give us a little insight. Thank You Amanda Markham amandam@summa-entertainment.com
SOURCE: nortel t7208
it seems like your system does not have disconnect supervision. set it to yes under trunk line data. that way the system knows when a call is released.
sean malone
Posted on May 11, 2008
SOURCE: ACCESS VOICEMAIL
You have to press the "Function" button (The grey one alone at the top of the keypad just under the display) then enter 981.
Posted on Feb 13, 2009
  • 9 Answers
SOURCE: Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
Posted on May 21, 2009
SOURCE: voicemail and password
I would unplug power to the voicemail, then restore. Wait 10 minutes and then do the same to the phone system.
What you are trying to do is reinitialize the voiecmail, if you dont know what you are doing you will do more harm than good.
Posted on Jul 20, 2009
  • 4 Answers
SOURCE: I NEED HELP RESETTING VM PASSWORD
Are you trying to enter the VM system by using FEATURE983?
When you have 3 digit extensions, you need to use 102 like you have tried. The password part of the login is the 0000. Someone must have changed it from the default 0000 to something else. Try 102**** where the **** is some other common password that you might use such as 1111, 2222, 1234 or others like that.
Posted on Jul 30, 2009
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Apr 10, 2015 | Nortel Norstar M7208 Telephone
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
May 10, 2011 | NorStar T7316E Corded Phone
Auto attendent voicemail locked
Go to this phone press feature 983 this takes you to admin change mail box .The general mbox is 100 this is the mbox you want to change
Oct 09, 2009 | NorStar M7324 Telephone
We lost the voicemail password!
If you have an in-house administrator, they can log in and reset it. You might try 0000 and 1234 just in case, otherwise you will have to call whatever tech help you have and get them to reset it.
Sep 03, 2009 | Nortel Business Series Terminal T7208 -...
Voicemail and password
Jul 20, 2009 | Nortel T7316E 2-Line Corded Phone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Voicemail-i need in
If she gave you the phone to keep then you don't need to figure out the voicemail password and she's still going to be out of luck. Voicemail follows your phone number, not the phone itself.
What she needs to do is call customer service for her cell carrier (Verizon, AT&T, whoever) and have them reset her voicemail password.
May 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Aug 21, 2007 | NorStar T7316E Corded Phone
Nortel Networks BSGX4e Business Services Gateway Router Logo
54 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
