Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mitsubishi WD-52525 DLP
I am getting multi color striped bands running accross my picture - simetimes verticle, sometimes horizontal and sometimes cross ways from top to bottom.
I suspect a bad light engine since the set is 4 years old.
Can I replace the engine without specialized tools or do you think I can hire a tech to use my part and charge me a service call?
  • 179 Answers
If you have a picture the engine is probably ok. this is a common problem with this is probably the main chassis (DM or FMT)
Posted on Dec 18, 2008
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like, to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I am having trouble with my Mitsubishi 52" DLP model WD-52525. It has large green horizontal stripes rolling up and down the screen. I have already paid my money here, and was disconnected before my chat...
There is a chance the video board is not working how it should. When a video board starts to fail it can start with these green lines and it can also give you a completely green or blue screen. In this case you need to take the board to a shop so they can check if it's either the digital or analog video board. The boards are not that expensive.
Dec 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp 52525 garbled rolling picture. Picture just colored lines, rolling slowly. Sound fine, fairly new lamp.
You most likely have defective capacitors in your electrical chassis. It's best to send the entire chassis back to the manufacturer for total rebuilding. The cost is about $350 + labor, unless you can remove the chassis yourself.
Good luck.
Aug 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
