Question about Prime 10 Amp Circuit Breaker
Blown breaker i dont know if i guessed my brand of circuit breaker. i went out side today. turned on porch light and POP! this time it poped the breaker. this time i cannot reset the breaker. usually popr sthe GFCU in the bathroom. i do have an outdoor electrical panel that might have got moisture in it from the snow and zero temps. i unplugged everything and cannot reset. all that is ran off this 15 amp, is the bathroom, the proch light and lights in the laundry room. the other half of the braker is fine and the rest of the house is fine. could this be my prob with the frozen wet outdoor plugs
    Sergeant:
  • 359 Answers
Any moisture is a problem gfci,s trip @ 25 milli amp to ground this is very little get rid of all moisture you can and spray outdoor recepts with some contact cleaner this is available @ good hardware stores and electrical supp houses and will displace all residual moisture
Posted on Dec 31, 2008
  • Allen Neal
    Allen Neal Feb 07, 2009
    did you try to reset with the porch light off if not try to reset with the light off if it resets replace the lamp ( or bulb ) and try again
    Scholar:
  • 35 Answers
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Posted on Dec 21, 2008
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Several lights went out at the same time. the porch light, bathroom light and fan & 3 interior lights
Check your panel breaker box, most likely you threw a breaker. NEXT TIME PLEASE POST QUESTIONS IN CORRECT AREA- THIS IS FOR VEHICLES! good luck and thanks for using FIXYA
Aug 25, 2013 | Electrical Supplies
2006 street glide radio fuses keep popping
Hi Jamie, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 06, 2012 | 2006 Harley Davidson FLHX Street Glide
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the thermostat but still no luck after confirming it was installed correctly. My S/N is 0407477962, Model VNC60C2A,...
Your thermostat can get power from either of two power souces. Primary power would be 24 VAC from a transformer mounted inside your air handler. Second (optional) power may be provided from battery backup, with the batteries mounted inside the thermostat itself.
Since your display went completely blank, then I would venture to guess that it is related to the 24 VAC circuit, sourced from the air handler. You probably do not have battery back up. Use a DVOM (Digital Volt Ohm Meter) to measure the RED wire connected to your thermostat. Make sure to use the VAC setting on the DVOM.
The "hot" side is the red wire, and will be connected to the "R" terminal in your thermostat. The Common side will be connected to most likely a blue, a black, or a brown wire. The Common terminal will be labeled "C" (but perhaps B) on your thermostat.
Since the thermostat is just plain dead you should next locate and check the fuse or breaker for the air handler control circuitry. There may be multiple different breakers/fuses for your heat pump's outdoor circuitry, its indoor controls, and its indoor resistive heat strips. Also, the circuit could be either 120 VAC or 240 VAC. Has one of them tripped or blown a fuse?
If you have breakers, then flip all of your breakers off and then back on. Stay near the breaker box and wait for a minute, listening/looking to see if any breaker has tripped or if a fuse has blown. Otherwise, if the circuit is fused, then examine or test the fuse. Again, use your DVOM, this time in the Ohms setting. Zero Ohms indicate the fuse is good. A very high Ohms reading is a blown fuse (infinite resistance) In this case, verify that the blown fuse is the CORRECT value. Maybe it isn't. Replace it with the correct amperage fuse. Again, wait a few moments and see if it the new fuse blows.
If either the new fuse immediately blows, or if the flipped breaker immediately trips, then STOP and call a professional. You have a high-power wiring problem. Call around, and find an expert. It could be that a mouse chewed thru some insullation. You don't know, but don't be sold on replacing an expensive component without verifiable proof of the source of the problem.
Otherwise, go back and check your 24 VAC "R" Red terminal at the thermostat. If it reads 24VAC hot now, then you have solved the problem, at least temporarily. You now need to know why the breaker tripped or the fuse blew.
If the circuit is on a breaker, then just replace it. They really do go bad after a while. Pop the old breaker out and bring it with you to the hardware store. Replace it with the correct brand, amperage, and configuration.
If the circuit was on a fuse, then (a) was it really the correct amperage rating? or (b) is there a chance that you had a hit from the power company or a nearby lightening strike? (probably not, or some of your computer/stereo/other stuff would have been knocked out too.)
Otherwise, you know the source circuits are good, and you know you don't have 24VAC at the "R" terminal of your thermostat. There are now more possibile causes.... to be continued. Marty
Dec 09, 2009 | Amana PTH123B25AJ Heat Pump Air...
Am making my Thanksgiving dinner today. The oven went out about an hour ago. When I flip the circuit breaker on, it goes off. If the stove is unplugged, the circuit breaker stays on. Help!
one of the burners is blown turn breaker off and remove top heater element then turn on breaker, does it stay on? if yes you found your problem burned out element that is shorting. pull one at a time till it stops resetting the breaker, be aware resetting the breaker more than 10 times considers they breaker not reliable but have personally not have had a problem unless it was 20 years or older.
Nov 28, 2009 | GE JBP24 QuickClean Electric Kitchen Range
I tried turning my Philips Flat Tv by pressing the power button on the side and a loud pop-noise went off and the tv havent turned on since, all I see is a red blinking lite in the left bottom side of the...
Unplug your unit for 5 minutes and plug it back in - turn it on - if problem persists then your TV's power supply is finished.
No it is not your circuit breaker or fuse otherwise you would not get ANY power to your outlet and would not see a blinking light. It sounds like a bad power supply.
This is may cost you a lot of money to repair - I hope your TV is under warranty.
Sep 20, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Circuit breaker on my air compresor pops
does the breaker pop with an empty tank?
if so then you need to see if the unit turns free,try running the m/c disconnected from the pump unit,my guess is that your drive motor bearings or internal windings are at fault
hope this helps regards ian
May 03, 2009 | Air Tools & Compressors
Lcd tv .red light flashes repeatedly but no picture or sound
That usually indicates power failure some where on the circuite board. If you heard a ' POP" a capacitor probably blew out.
If you knew enough to repair it your self, then you wouldnt be asking and if you dont, then you should take it in for repair by a shop, unless its a cheap t.v., in which case, buy a new one.
You would need to locate what poped and try to obtain a replacement part, then soder it onto the board after removing the bad part.
If you dont know what your doing you could shock or kill yourself, start a fire or damage the T.V. further.
The cost for repair may be as much as buying a new HDTV so be sure you know what its going to cost before dishing out cash to a repair shop.
Good luck
Feb 01, 2009 | Computers & Internet
Prime 10 Amp Circuit Breaker Logo
538 people viewed this question
Top Prime Electrical Supplies Experts
Gene Haynes
Jim London
Jim London
Steve
Are you a Prime Electrical Supply Expert? Answer questions, earn points and help others
