Question about Panasonic KX-TG4500B Phone
Base Unit does not work
In the past month, I've had three different base units completely stop working. Reset button doesn't do anything, replacing the battery seems to solve the problem, but only for about 24 hours, and then the base unit is completely dead again. HELP!!
  • Roberta Smith
    Roberta Smith May 11, 2010
    base units or handsets ?
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Posted on Dec 18, 2008
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
I have the Dect 1683 with three handsets. We had a hurricane and the power went out and not all three handsets read "Searching" and I get no dial tone. When the phone rings it rings but you...
Hello
Just unplug the base unit from AC wall power socket for a while, say for about 5 minutes or so, replugh the base unit to power socket again. Place each handset on it and synchronise it with the base unit. As you put it on, you will hear a beep sound. Now the ahndset ahs been synchronised with base unit. Do this for the other two handsets. OK.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Telephone...
My att cordless phone mics went dead - on all three handsets!!! People call in, I can hear them and they can hear me. I call out, I can hear them but they cannot hear me. Any fixes? Phones are barely 3...
It's not that the handsets have bad mics, the problem is in the base unit. That's what's sending audio into the phone line, and something has gone wrong there. Try unplugging the power from the base and give it a minute, then reconnect the power. This will allow the computer inside to reset and may straighten out the trouble. If it doesn't, you're probably best off replacing the system.
AT&T doesn't say anything on their site about service, just to call their Customer Support and Service Center at 1-800-222-3111 for more information. If your phone is out of warranty, it's probably easier and maybe less expensive to buy new.
Jul 28, 2011 | AT&T 650530003417 Cordless Phone
We have a DECT 6 system with a base unit and five satellites. Suddenly the satellite phones don't work, but they are alive (with no dial tone and don't ring) and show a message "out of...
Hello.
From FixYa Support:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
Perform steps for each handset. You may need to plug base unit and unplug for each handset.
Hope this helps.
Jul 27, 2011 | Uniden Cell Phones
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
I bought 2 new handset for my Panasonic KX-TH112. Following the instructions in the manual, I tried to register them. I had trouble so I called support. The tech had trouble too and asked me to unregister...
My phone does the same thing and has done it periodically since I've owned it. The buttons on the base unit stopped working a few months after I purchased it, at the moment I have what sounds like the same problem as you, the display stays backlit and the highlight switches from one menu item to another while beeping.
This doesn't, however, prevent the phone from working fine.
The only thing I've found that *may* fix it is to swap the power adaptor for the base unit with one of the adaptors hooked up to the handsets.
I don't want to give up my phone yet because I can't find anything anything similar from any manufacturer, with two lines and the ability to pair our cell phones with the base unit so I'm in the market for a replacement base unit and I may send mine to Texas.
Nov 03, 2009 | Panasonic KX-TH112S 2.4 GHz Cordless Phone
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Panasonic Phone KX-TG6700B base unit Problem
FROM PAGE 38 of the manual:
If "No link to base. Move closer to base, try again" is displayed, even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit..
HAVE BOTH THE HANDSET AND THE BASE UNIT NEARBY DURING REGISTRATION.
FOLLOW STEPS 1 AND 2 LISTED BELOW. YOU HAVE ABOUT 1 MINUTE TO COMPLETE THEM.
1-Base unit:
Press and hold [HANDSET LOCATOR] until the CHARGE indicator flashes.
2-Handset:
Press and hold [FLASH/CALL WAIT] until "Handset Registering" is displayed.
-When registration is complete, a beep sounds from the handset.
-Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
If... the handset beeps three times and "ERROR!" is displayed, an error occurred. Try again from step 1.
You can stop registration by pressing [OFF] on the handset, and pressing [HANDSET LOCATOR] on the base unit.
Jan 10, 2008 | Lands Phones
Phillips VOIP841 skype phone
DeRegister the handset and then reregister it to the base
On handset
Menu
Settings
Handset
Deregister
Then
1 ) press Reg. Register shall be highlighted.
2 ) press Page key on the base unit until the two indications turn off.
If registration is successful,the signal icon 070928095554_21019.bmp displays steadily.
If registration failed,repeat the above procedure.
Sep 17, 2007 | Philips VOIP8411B/37 IP Phone
Panasonic KX-TG4500B Phone Logo
293 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
