Does'nt work the pilot light is on but the gas is not coming
    President:
  • 2,992 Answers
The most likely problem is a bad thermocouple. Pilot-equipped appliances have a thermocouple to make sure the pilot is lit before turning on the main gas flow. You'll see the end of the thermocouple looking like a metal rod sticking into the pilot flame. Replacing the thermocouple is not difficult. There's a nut that holds the thermocouple into the pilot assembly, and another that holds the thermocouple lead into the main gas valve. Universal replacements are available for under $10. Several websites have good step-by-step instructions if you need them.
Posted on Dec 17, 2008
2 Suggested Answers
  • 10 Answers
SOURCE: pilot light
Pilot orifice may be clogged. Remove pilot tube and orifice. Blow out orifice with compressed air only and reassemble. Also, control valve may be bad.
Posted on Feb 05, 2009
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
Pentair minimax nt explosive ignition
Problem is an obstructed gas oriface. The burners light from the burner closest to the pilot assembly out like a dominoe effect. The explosion is because the gas has to make its way over to the pilot from a further burner thus filling the firebox full of gas before it ignites. This blockage is most commonly from a spider web inside the oriface itself. Pull the burner tray, remove the orifaces from the tray and look through each one cleaning them out with a toothpick from the backside. The orifaces should be threaded on the gas line coming off the gas valve (looks like a silver box inside the front panel)
Feb 16, 2012 | Pentair Minimax NT Heater
We have a Rinnai 2000D heater. The pilot light goes out and is then difficult or impossible to restart. The igniter is working and there is the smell of gas, just doesnt seem to be enough gas there to...
you can try cleaning the pilot light with sand paper, (where the hole in the end is where the gas comes out) they get carbon built up over time and causes the hole to get smaller which makes the pilot light not want to stay light because of the small amount of gas coming out.
Sep 25, 2010 | Rinnai Heating & Cooling
Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition...
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Aug 25, 2010 | Heating & Cooling
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Pilot light has no gas coming out, verified gas going into gas valve, but no gas coming out when pilot light button depressed.
Sep 30, 2008 | Cozy Enclosed Front Console Heater 20,000...
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
