Question about Bosch Axxis WFL 2060 Front Load Washer
Won't spin Pumps but won't spin. Everything else is ok
  • reuse3 Dec 21, 2008
    Yes I took them out and cleaned the holder and it works great. I will look for some new brushs as they are short.
    Thanks Earl
  • Bosch Master
  • 3,463 Answers
The most obvious thing that comes to mind is that the brushes need replacing in the motor
You will have remove the motor to check them.
The brushes are located at the rear end of the motor, you will see the wires going to them
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
Why does spin cycle cut out before hitting max RPM?
G box or timer not staying on long enough
Sep 03, 2015 | Washing Machines
Can't get my Hayward Northstar SmartMax pump to pull water, it only makes a noise and does not pump water
Have you looked at the vanes in the impeller? if they are significantly clogged nothing will pump or flow.
Oct 24, 2012 | Hayward 1.5 Hp Northstar High Performance...
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Can i use my washing machine with no lid switch
as long as everything is working it's ok,all it is is a safety switch so the washer won't run with the lid open,a kid could open the lid when it's spinning and it won't shut down and if the kid sticks his or her hand or arm inside it could get ugly so it's a safety switch that's it.
Feb 22, 2012 | Kenmore Washing Machines
Machine pumps and drains, but the drum won't go round in wash, rinse or spin cycle. I have checked the bushes and they are ok. I cannot see any error code. Bosch WFX145SGB
Bosch WFX145SGB This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Washing Machines
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Sep 06, 2008 | Maytag Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
97 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
