Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Hi fixya have a problem reattaching  keyboard letter somehow removed by my 2 year old
  • Philbert07 May 11, 2010
    It will depend on the type of keyboard that it is on.
    On some laptops, the keys can be pressed back down into position and they 'click' into place again,
    on others they need to be pressed down on one edge, then after that clicks down, the other side of the key should be pressed down till that clicks too.
    But on others, they need the little plastic arms underneath to be carefully guided back into position, usually using a very small screwdriver as a guide.
    There are many different models/designs of laptop keyboard, so it may help to say exactly which model it is - e.g. DELL INSPIRON 2650 or maybe google the model and problem, such as;
    DELL INSPIRON KEY REFITTING (just an example search of course).
    It may help to find a photo of the assembly too, so it becomes clear how it is to be arranged during fitting.
    Before you try refitting, make sure you have the small plastic arms too, as they are essential for all keys. If it's a longer type of key (such as a space bar or ENTER key, you may also need a metal rod that goes under it, and some have small springs in there too.
    As a general rule, laptop keys have two arms under, which cross over each other to create a scissor action as you press the key normally, and a rubber part underneath then pushes the key back up again.
I have a dell inspiron mini 1012 netbook... The other day when I went to type the keyboard typed itself. Now it stopped typing itself but another problem occurred. When I press 1 letter, 2 letters pop
You can try removing the keyboard and reinserting. You should find instructions online, probably a video, on how to remove the keyboard. However, my bet is that it probably has to be replaced.
Sep 25, 2014 | Dell Inspiron Mini 1012 Netbook...
Acer shift button not working.. when i press shift and a to get capital letter a, nothing happen.. so, my solution is... use on screen keyboard... but, it's very complicated...
If a is typed as captial "A" via caps lock on!
Then I am sure your keyboard track of shift key gone bad!
Conform the same with Laptop vendors!
Apr 22, 2011 | Computers & Internet
I want 2 use my computor 2 right a personal letter and ime no further on wen i am asking this simpel qwesion ime new on computors very new but instead ov getting a answer i am being asked a pay fof this...
use either word word-pad they are usually found behind the start button it will open up when you click on it don't forget to spell check usually a check mark looking thing and either press print or the left control button on keyboard and p on keyboard it should then print your letter
most public libraries offer beginners classes
and you can always access help in any program by hitting the f-1 key at the top of your keyboard
my 70 year old mother and 90 +year old grandmother took the classes because they had no idea then at most of what i was saying and now they are as proficient as anyone
good luck and please vote
Nov 30, 2010 | Computers & Internet
My hp wireless keyboard is locked my 2 year old was typing me a letter and know the keyboard is locked.
Suggest looking for a stuck key... sometimes a key stuck down will disable the keyboard.
Nov 29, 2010 | Computers & Internet
Mac laptop keys are not showing letters but symbols and delete key not working. How do I unlock this problem?
There could be a couple of possibilities :-
1. Faulty keypad
2. IC on the main board
Faulty keyboard is more often a problem. Even though there is no dust and dirt, faulty keyboard may result in all the above said symptoms.If you press a letter key, a symbol might be there. If you press delete key, it might not work. The best option what i follow in my shop is replacement of keyboard. There are certain days when i only replace few keys, but more often if this is a problem with more than 5 keys or with all the keys on the notebook, better to go for a new keyboard.For your laptop, always prefer hard keys as those are more durable than the soft keys.
IC on the notebook is again one of the reasons. This is usually a problem with old laptops, such as 5 to 7 years old. New laptops generally do not have this problem. If laptop IC is at fault, soldering is required to get it fixed.It needs a tech to confirm the faulty IC on the mainboard and then followed by replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 03, 2010 | Computers & Internet
Okay when I type the letters on the top row I also have the number closest to it for example when I type e it comes up e3 or E# that happens with every letter on the top row or vise versa number and letter...
Your keyboard is faulty - either due to a mechanical failure or spillage.
This is pictures of a different brand, however the premise is still the same...
An easy repair - remove the top trim bezel (just under the screen) this will allow access to 2-3 screws.
Remove the screws, and tilt the keyboard out.
Remove the ribbon cable.
Install reverse of removal.
thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Dell 0Y3740 Keyboard
Have a RCA model HD 52 W59 rear projection tv
Hi again,
Sorry, but for some reason the session was disconnected. Our apologies for any inconvenience.
If you would close the session at your end, you would be presented with options. Hopefully, the system would allow us to continue through the transcript although not real time.
I am hoping for your kind understanding and that we can somehow continue to resolve your concern.
Thank you for using FixYa.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Multiple letters typing at once
Try Uninstalling the Keyboard Device, then re-installing it through the add/remove new hardware section.
Dec 01, 2008 | Computers & Internet
HP Keyboard
adere some super glue to the outter circle of the F key underneath and push it back into the silicon. make sure you don't keep the key pressed down while the glue dry.
Aug 21, 2008 | HP D8597A Keyboard
goto control panel/keyboard and check the character repeat settings.
Oct 05, 2007 | Computers & Internet
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
171 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
