Cleaning the circuit board of a tv with electronic cleaner
Standard Zenith TV, Can I clean it without losing the connections on the board?
  • 121 Answers
Yes. i used carb cleaner. and toothbrush.
Posted on Dec 17, 2008
There is a burned capacitor cx3210 and melted thermister thx3415 in Zenith B36A24Z Can dirt cause this problem from overheating or arcing?
When more dust accumulate, and absorbs moisture from the atmosphere, ther is a chance to get arcing. Clean the device by using a vaccum cleaner if possible. Burned degaussing coil cannot be repaired. It should be replaced along with degaussing posistor.
May 08, 2012 | Zenith B36A24Z 36" TV
What's the best way to clean my TV screen?
You can buy cleaner solution from electronic spare part selling shops. It is the best way to use it to clean your tV.
Apr 27, 2012 | Samsung Televison & Video
My cable connector is broken off the back. its a 1343 model. I would like to use cables to connect it to a DVR.
If you are electrically inclined, you can replace the cable jack on the TV ... but it will require some doing. You will have to open up the TV and find the circuit board with teh coax jack on it. take a soldering iron and remove the coaxial jack from the circuit board. Make sure you don't overheat the circuit board while you are doing this, or you will burn out the whole board. Once the jack has been removed, take it to Radio Shack, or a similar store, and find the exact same part. Then reverse the process -- attach the jack without overheating the circuit board, and put the TV back together. ****If you are not VERY good with electronics, don't try this unless you are not afraid of losing the TV -- it is VERY easy to burn out a circuit board.
If there is a TV repair person in your area, it would be a good bet that they can fix it for you at a reasonable price -- just be sure to tell them that all you need is to have the coaxial jack replaced. This way they can only do what you are asking for, and can't charge you for repairs you did not need.
May 27, 2011 | Craig CTV-41331 13" TV
Zenith 27 inch text is blurry
This tv needed CRT Tube discharge.Take the tv aparts,take out the CRT video board,must plug it back in."Highvoltage becareful",find a wire with good insulations,grounded itself in with a screw from a steal frame.High voltage "Take that wire go close to the CRT tube without the video board connect in.Than u will hear a pop,that the highvoltage,just discarge ur CRT bad contamination.The tv should be clear now,after putting it back together again,getting it working.
Dec 30, 2010 | Zenith B27A11Z 27" TV
How to clean the screen
Use a soft lint free cloth and any glass cleaner. The trick is to spray the cloth instead of the TV screen. Spraying the screen itself could let cleaner run too far down and on to the circuit board. Thanks for using fixya.
Dec 06, 2009 | Philips 27PT6441 27" TV
TV comes on when it wants to
If the TV "goes out" meaning that you lose tuning (picture gets very snowy, disappears totally, etc.) but the power stays on and is otherwise normal, the trouble is often because of bad connections inside the tuner.
It is possible to remove the tuner from the circuit board, open it up and resolder the connections that typically go bad. (Usually they are solder joints connecting the ground traces along the edges of the tuner circuit board to the metal box it mounts in, and some other ground points on the board. Often they are visibly cracked.)
To this requires electronic soldering skills and the tools to make the repair. It is possible to do additional damage to parts because of small connections, fragile parts and so on), so this may not be something you want to try as a first project. But if you can do the soldering and are patient, it is possible.
On the other hand, if "going out" means the set suts off completely, there are too many things that might cause this to offer any suggestions for things you might try on your own.
Jan 23, 2009 | Zenith B25A11Z 25" TV
A27A23W TV key circuit board
the keyboard on this is no longer available from what I see, here is the correct part number for assy. F-52954
Nov 09, 2007 | Zenith A27A23W 27" TV
Remote control Sensor for tv
The IR sensor on the main circuit board may have gotten zapped or possibly the window where the IR signal passes through may need cleaned. It's located on the front of the set near the control buttons. Stargazer
Aug 18, 2007 | Zenith SY2723BW TV
Tv troubles
the fluid has found its way down to the buttons. Slide the circuit board out and clean the switches with an electronic contact cleaner and toothbrush, it will evaporate quickly but make sure it is dried and give it a try.
May 11, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
