Question about Hotpoint RGB524 Gas Kitchen Range
Frigidaire model FGF316BSB range
My thermostat knob won't push in and start the oven. The knob used to push in but is now "frozen" and won't push in. I want to remove the thermostat and replace it. Is this easy to do?
  • 125 Answers
SOURCE: Hotpoint Gas Range (model: RGB524PN1AD)
The knob could be stripped or cracked. Try to shut it off with a pliers, careful not to damage the shaft. If thet works get a new knob.
Posted on Jan 21, 2008
bigg t
  • 640 Answers
SOURCE: Viking Range VGIC4856GSS
Goto this site. http://www.3wire.com/foodservice/?OVRAW=northern%20parts&OVKEY=northern%20part&OVMTC=standard&OVADID=6566743522&OVKWID=55119092022 they should help you out.
Posted on Feb 16, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
  • 341 Answers
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
milten1
  • 1304 Answers
SOURCE: Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Posted on Oct 09, 2009
Don't know how to set clock on frigidaire range model # RG94BF*0 please help
There are 3 knobs below time display and one to the right.
Push the right 2 buttons at the same time while turning the right knob to set time..
Apr 06, 2011 | Frigidaire Ovens
Oven is not working
Hello there:
Just to clarify if yu are talking about the entire oven not working than check out these solutions
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to. Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors. HOWEVER IF IT WILL NOT BAKE OR BROIL
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Nov 19, 2010 | Frigidaire Kitchen Ranges
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Jan 15, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Oven won't work
This could be a defective ignitor (glow bar) or gas valve (safety valve). If you gently tap the safety valve and it lights up very likely ingnitor problem
Regards
Jul 26, 2008 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Jan 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Oven thermostat - schoenberger gas system 1975
Will need to find the correct model # somewhere on the range then go to www.appliancepartspros.com or www.www3.sears.com and you will find it there. I found thermostats on those sites for a model # close to yours and most likely the same one. Sears was about $72 and appliancepartspros was about $78. Hopes this helps.
Oct 08, 2007 | Tappan TGF320 Gas Kitchen Range
Hotpoint RGB524 Gas Kitchen Range Logo
117 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
