Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
WeatherMaker 8000 noisy fan
I have 2 fo these units, the fan/blower bearings were shot after 5 years. Now this is the second unit [about to fail], just 8 years old. Can someone help me locate parts, I want to repair it myself, I just don't have the cash right now for a pro.
  • 700 Answers
You can take the parts of and match them at a graingere supply if theres one cloce to ehre you live. I think that it has a 1x1/16th" diameter on the blower bearing and its for a spider type. Try not to tightn the belt so much and the bearings might last longer
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Dec 21, 2008
    sorry i thought that iut was a package unit. opps
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
I am hearing a little bit of squealing noise when running the ventilation fan in my house.
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Oct 20, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Thermostat doesn't activate unit
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Jan 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
Jul 07, 2010 | Heating & Cooling
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My A/C (Carrier weathermaker 8000 hybrid) is not cooling properly
set the t-stat low and let it run for 5 minutes , stick a thermometer in the return air closest to the unit as possible until you get a good reading , then stick the thermometer in the cold air supply again closest to the indoor unit as possible let sit until it stops going down in temp.
this is called your temp difference and it should be atleast a 14deg. F difference from in to out. if its lower you have a refrigerant problem, Let me know how it goes.
Phil
Jun 10, 2009 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
817 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
