Question about Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator
Kenmore fridge with freezer on top/condenser bangs
Fridge on rollers,tilted fridge to clean coils under fridge after cleaning i releveled fridge by adjusting rollers. Now the condenser bangs and rattles when it shuts down.rubber shocks are okay and soft,insulation is intact,when i manually shake condenser it sounds like a ball or bearring is hitting on the inside of condenser bowl. fridge was quiet as a mouse till i cleaned it,now everytime it shuts down it klunks,hope you can help me out,Thanks in advance.
    Sergeant:
  • 359 Answers
Check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Posted on Feb 03, 2009
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Hi there i have bought whirlpool fridge freezer 6 yrs back till now it was working ok but recently we have noticed our milk and vegetables started getting spoiled in 2 - 3 days. i have been told to clean...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Refrigerators
Kenmore frig does not turn off
How are the door seals doing? How clean is the under side of the fridge (the coils and the ability for air to flow). How clean is the back side of the fridge (the coils and the ability for air to flow). How clean is the metal jacket in general?
If you drag the fridge outside to hose it down, let it rest for an hour or two before plugging it back in.
Jun 03, 2011 | Kenmore Top Freezer Refrigerator
Freezer is working OK (ice cream soft), refrigerator is not working...milk spoiled etc. What to do? Possible self-fixes?
Check under the fridge to assure the coils are clean, if not vacuum and clean with a brush accordingly. While you're down there, make sure the condenser fan motor is turning. Check inside the freezer compartment to make sure the evaperator fan is running.
Jun 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator condenser banging
yeah, you must have knocked the compressor when cleaning, sounds like one of internal spring/mounts in the comp' has dislodged.
replace the compressor is the only fix, unless you can somehow get to the lose spring.
Apr 25, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge too cold
First, clean it the unit out and fully defrost.  Clean the condenser coils.  Don't pack in so much food, don't open the door too frequently.  Never block any air channels. Never leave uncapped liquids in the fridge or freezer.  Set the fridge at about 40 degrees...use an outdoor thermometer.  Freezer at about 0-5F.
Aug 21, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
