Question about Kenwood AR-304
On and off switch
Hi, thanks for letting me post my problem with you, i have a kenwood Ar 304 recevier, and when i turn on the recevier its shuts itself down in 3 sec, and then the stanby light blinks, What do you think?
  • 97 Answers
This is the thermal overload for the amplifier section. unplug unit and check all speaker connections for a crossed wire. After all connections are checked and are in good condition, plug the amp back in and power up. Note: the polarity of the speakers when the wires are plugged in. Use the painted line on the speaker wire as a guide for which one is positive(+) and negative (-). If an amplifier is operated out of phase for too long ( positive and negative reversed), you can damage the amp. A bad speaker coil can cause the overload as well. If it still does it, disconnect all speakers and power it up. If these remedies do not solve it, you amplifier IC is shorted and needs replaced.
Posted on Apr 12, 2007
I have a Kenwood AR-304. Does this receiver have an HDMI input? I'd like to use Google Chromecast to stream music through it. Thanks!
Look on the rear panel .You should see a (HDMI IN) if it does
All others are labeled (HMDI 1) 2,3 etc.. outputs
Oct 03, 2014 | Kenwood AR-304
Audio output connection s
http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/ar304.pdf
Apr 06, 2014 | Kenwood AR-304
My kenwood 107VR keeps turning off on its own, after about 3 secs it shuts off and the light blinks.
If you are sure your speakers are good. This unit has a protect circuit keeping the unit from turning on. This recevier uses an ic instead of output transistors. A ic incorperates transistors,resistors,capactors in one assembly for size and costs. There is a number right on the front of the ic ,you can go on-line to buy the ic is is fairly easy to put in as long as you can desolder and solder in.
Apr 17, 2010 | Kenwood VR-209 Receiver
Hooking up Kenwood AR-304 to LG TV
You need to connect the TV "Monitor Output" which will be standard audio (RCA) red and white. Then you need to make sure you go into the TV's main menu and go thru "Audio". You may need to turn off the TV's internal speakers to get output via the RCA monitor out. If by chance it has a setting for "Fixed or Variable" for the output, select "Fixed" and control the volume thru the receivers volume control. If you still need further help, don't hesistate to ask! I can walk you thru it. Hope this helps
Aug 18, 2009 | Audio Players & Recorders
Hook up for an AR 404 receiver
Copper is positive, aluminum is negative. OR One of the wires should have a white (or black) stripe on the insulation...this is negative wire. OR If using 18 gauge extention cord wire, the positive wire will have small grooves running the entire lenght (very difficult to identify, unless you have good eyesight) Hope this helps.
Jun 11, 2009 | Kenwood AR-304
Turns on then shuts off like it has a bad fuse
HI...
Check to see that all the speakers are firmly connected at BOTH ends.
Also,if the receiver has speaker select switches, see if turning off the speakers allows it to stay on.
Let me know , Thanks
Feb 08, 2009 | Kenwood Audio Players & Recorders
Do I need a new equalizer?
Karla, Equipment and water especially SALT water (AND SALT AIR) don't mix very well. The constant high moisture environment affects all the connections (the wires) the rca connectors (where one thing plugs into another, AND the switches. The wires may LOOK good but the connections may not be. When you say "all seems to be in good condition" tell me specifically how you checked them. Sometimes they LOOK good, but ar not making connection. While your stereo is ON, get in there and wiggle everything and see it the speakers come back on.
My first guess is your amplifier/reciever. Does it have speaker switches? If it does, move them up and down or click them many times to see if you can work the corrosion a little. This may help.
I'll try and help, let me know some of the stuff I've asked fo above.
Feb 22, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
May 23, 2017 | Kenwood KR-A5080 Receiver
Kenwood AR-304 Logo
211 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
