Cannot see my other computers via my zoom adsl x6 router,have ran the xp network wizard on all machines
    Genius:
  • 1,605 Answers
You need to setup each machine on the same IP address and share enable. ADSL only enable all of the machine to connected using a single device, and sigle IP address to access the Internet.
Posted on Dec 17, 2008
  • Frank
    Frank Dec 17, 2008
    if you want to know exactly how that is setup. email me at frcs68@hotmail.com.
    the porcess is long, and some time it need to be resetup few times before it really works well.
Is the Zoom ADSL X6 modem router supposed to provide connectivity for a 3G Kindle? If so, how do I set things up?
Zoom X6 routers don't work with either Kindles or Nooks- it seems the connect on demand to save power confuses the Zoom router - typically requiring the unpractical fix of rebooting the router every two minutes.
Feb 03, 2011 | Zoom X6 Adsl Modem/router Rohs...
Can i use my zoom x6 model 5590 adsl wireless router if i have i dont have a house phone? my internet is used through my cable
yes there is one way if you dont have a house phone. if you have a cellphone turn it on and put it on top of your machine.
Jan 03, 2011 | Zoom X6 Adsl Wireless Gateway Rohs Router
My modem shows no nat loopback and I need to access a server running inside my network and I can't while everyone else can
I was told by ZOOM a long time ago that the X6 ADSL 2/2+ modem does not support NAT loopback.. :(
Mar 27, 2010 | Zoom X6 Adsl Modem/router Rohs...
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
My zoom ADSL X6 works well for my ethernet. Yet
hello. with regard to your concern.. the network key is probably under the adsl x6 or at the side of the device.. if you cant see it.. try to access the setup page, but you need to know the default gateway of your adslx6, to check the ip address right click the network icon on the lower right taskbar of your computer and select on status, select support and it will show the details.. ex. your default gateway is 192.168.1.1, pull up a brower and at the url, type the default gateway, 192.168.1.1 then it will ask for the username and password.. after entering the username and password.. go to the wireless setting and it will show there the network key..
Aug 06, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Lost soft wear zoom x6 adsl router
Choose your router here:
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
Apr 03, 2009 | Zoom X6 Adsl Modem/router Rohs...
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Need Zoom X6 help unresponsive
make sure your ethernet port is set to 'obtain address' and 'DNS' automatically (IE use DCHP and not static IP address) The software should be able to 'find' the zoom modem then.
Jan 22, 2008 | Zoom X6 Adsl Modem/router Rohs...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
