Question about Whirlpool LEB6300 Electric Dryer
Dryer is on and tumbling, but not heating up
I suspect that my heating element may be out but I can't figure out where it is in the back of the dryer. I cleaned the lint out of the vent hose to make sure its not clogged and I flipped the circuit breakers in my panel to make sure the wasn't the problem. I opened up the back of the dryer, but all I see are a few wires. I don't have any sort of ohm meter or anything like that to test for current. The dryer runs fine, however it is no longer drying the clothes. I cleaned all the lint out and put a new vent hose on. Still not drying. I'm sure it's the heating element or the thermostate ( same thing ).
  • 1 more comment
  • swbaker1152 Dec 17, 2008
    No reset button on this particular model
    Hey pc6493 any other advice would be greatly appreciated on the dryer not drying. I looked for a reset button and found nothing. I took the back off, the appliance guy is to come over in the morning. I would like to try this on my own, because the appliance man is expensive. swbaker1152.
    Thanks pc6493.
  • 20 Answers
Most driers have a overload cut-out switch to protect the element from overheating
these are usually on the right hand side of the ( Bump / hump panel at the back ) should be a plastic thpe button that re-sets the overload
- got to be worth a try
Posted on Dec 17, 2008
  • pc6493 Dec 17, 2008
    Hi
    Think very carefully about paying for a drier repair as they have come down in price a lot ( Dixons / Currys are very competative ) Try www pricerunner
    Now some heating elements are WELL hidden so -If appliance guy is coming ask for a FREE quote- leave off back cover and ask him to point out what he will be replacing
    you will then know where element is - price one yourself and decide next action
Dryer not heating up trying to figure out where fuse is located
some tumbles have a rubber circle reset in the centre of tumble at the back,this is the thermostat.if not they may be internal.they are metal circle things,they may need replaced.id say a new thermostat is needed.may also be the heater element,need more info
Mar 19, 2013 | Kenmore Dryer /stacked Washer Washer Dryer...
My beko drcs 76b tumble dryer isnt heating up
First turn of the breaker, then back on. Check the wiring from the plug at the receptacle to the back if the dryer. You should find your problem there. Then next is the element. See if the wiring is ok to the element. Next visually check the element for
Mar 10, 2013 | Dryers
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
First and foremost check your breakers. There will be 2, 30 amp breakers. Even if they don't look tripped reset them anyway. Then try the dryer if that's not the problem then you either have a thermostat problem or heating element and will need to check with an ohm meter.
Dec 07, 2007 | Kenmore 63942 Dryer
Whirlpool LEB6300 Electric Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
