Question about Microsoft Xbox 360 Console
Signal my signal on xbox is showing connected but when i do the sttings it says wireless not connected
  • 84 Answers
There might be a problem with the DNS (domian name server)
try reseting your router and xbox then reconect
many DNS problems occour from on overused router and wireless
this used to happen to me costently but microsoft gave me the same advise ive given you
Posted on Dec 17, 2008
How do u connect an an xbox 360 to xbox live
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
Aug 24, 2011 | Microsoft Xbox 360 Console
I was having trouble getting a signal on my xbox 360 so i unplugged and plugged my router back in, this caused it to not put out a wireless signal, it does produce internet through an Ethernet cord, but...
It can take up to 2-5 minutes before your router starts broadcasting a wireless signal and for the xbox to be able to connect to it, turn your xbox off and the router wait a minute then turn your wireless router on, wait a further few minutes and turn your xbox on and try using the wireless connection
Jun 27, 2011 | Paradyne Zhone 6218I2 ADSL2+ 4 Port WiFi...
Wireless signal being fully picked up by xbox but still cannot join xbox live .xbox says test failed even though all bars are showing full wireless signal
It could be a problem with the xbox not being allowed through the router's firewall. You can check/remedy this by opening a "port," that, if it is the case, is currently close, blocking the xbox's connection to the internet. To do this, check out this site :
192.168.1.1 It should bring you to your router's page, where you can open/close ports. You can also try following this tutorial for instructions.
http://forums.afterdawn.com/thread_view.cfm/223583
May 01, 2011 | Video Game Consoles & Games
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Testerday we connected to xbox live but today we cant connect why
Are you wireless or are you wired. If you are wireless, sometimes phone signals interrupt the wireless signals if you have a wireless phone nearby. Some wireless phones are very messy with the signals they send.
Jan 01, 2010 | Microsoft Xbox Console
Xbox 360 wireless
There should have been an instruction manual that came with your wireless adapter. But anyways, you may be connected to a password protected router and need to put in the password via the dashboard. I'm pretty sure you would goto network settings and then select the network you'd want to connect to.
Dec 29, 2008 | Microsoft Xbox 360 Console
Microsoft wireless adapter
Do you have a Router Already? If not you need one. If you already have one. Then just text X-Box live connection sttings, and you should be all set to go. Hope this helped.
Jul 13, 2008 | Microsoft Xbox 360 Console
Wireless security to xbox
assuming you mean xbox360, there should be a seperate menu for wireless connections in the network settings, as when it finds the signal it then asks for the keycode security number, but as far as i know the old xbox doesnt support wireless.
Sep 09, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Microsoft Xbox 360 Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
