Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
I have a 3 year old Toro Snow King. It is sometimes dropping out of gear.
This Am when I was backing it up in #2 position reverse (the faster one,after a few feet it stopped moving). I placed it in the 1st position and it worked. I stopped and placed it in the 2nd position and it worked OK then.
This also happen in the forward gear #4. It happens infrequently. I want to know if something is starting to give out. It looks like another big winter here in Wisconsin. Last year was the 2ndhighest snowfall on record. We are on the same track this year.
SOURCE: Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Posted on Jun 06, 2009
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
SOURCE: I have a Toro 20332 that stopped running after 20
Just take off your carb and give it a good cleaning. Be careful and watch how everything comes apart so you can put it back together with little or no trouble.
Posted on Jun 08, 2010
SOURCE: My toro 1028XL stopped moving
I viewed a parts diagram at www.arcolawn.com and your machine is equipped with a shifter under the battery in the back. If the shifter is loose to shift the ball socket of the ball joint that attaches the shifter to the transmission is broken. If you can hear the gears shift but the unit will not move it is a problem inside the transmisson. I recommend checking out the parts drawing at www.arcolawn.com you can get what you need super fast.
Thank you
Joe
if this was helpful please vote me up.
Posted on Feb 12, 2011
Dec 30, 2017 | Toro Garden
Feb 15, 2015 | Toro Snowblower 826 Oxe 38624w With 3 Year...
Feb 10, 2015 | Toro Ccr Snowblower
Dec 16, 2013 | Toro Power Max 726 OE Snowblower - 37771
Dec 14, 2013 | Toro Power Clear 221 Electric Start 21...
Dec 07, 2013 | Toro 38644 Power Max 1028OXE 2-stage...
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Jan 09, 2011 | Agri-Fab Agri - Fab Snow Blower - 42"
Feb 28, 2009 | Mowtownusa Snow Thrower Starter Switch for...
59 people viewed this question
