Question about Vtech i6772 Trio Cordless Phone
Searching my vtech cordless phone attatched to the base unit indicates searching i"ve tried everything from resetting the power supply the cord and removing the battery but to no avail. The two other handsets are working properly it's just the base unit tha't not. I can't use it as it doesn't have a dialtone. Please help
  • Lauralu Feb 06, 2008
    The power went out the other day and now I have the same problem. All three headsets say searching. The answering machine still works but nothing happens when I try to dial on the phones. I have tried unplugging the power cord as well as the phone cord to reset everything.
  • shrif shrif Feb 11, 2008
    I am me Phone 6773 any handset is completely separate from the cabin Every time I show the word
    Enter base id A 15-symbol
    I know I find loss coverage Fein if one can tell me how Atsrv knowing that I addressed the company is not listed on the problems
    my emil : shrif_shrif_2006@yahoo .com
SOURCE: VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Posted on Apr 18, 2008
SOURCE: phone not connecting
I find that unplugging the base unit power for about 20 seconds, then replugging it, usually clears this problem.
Posted on May 01, 2008
AlmostBob
  • 550 Answers
SOURCE: Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Posted on Aug 30, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
SOURCE: i want to add an additional handset to my vtech phone...the new handset is "searching for base" and requests a 15-digit number which is suppose to be on the base--there is no 15-digit number to input.
The 15 digit number shoudl be on a sticker on the bottom of the base unit.
Posted on May 19, 2009
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
Out of range or no pwr base vtech phone on help
Try disconnecting the base from the power supply. Then take the battery out. wait a few minues, then plug baack in and reinsert the battery, and it should work. You might have to reset the date and time. \check the V-Tech site for instructions.Good luck.
cherriwh
Sep 10, 2012 | Vtech 9009111 Cordless Phone
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
We had a power outage and now the answering machine displays an A that we can't get rid of. Now matter what we do the system no longer works.
Try unplugging the base unit and removing the batteries from all the handsets. Then put the batteries back in and plug in the base unit to see if that resets everything.
May 02, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Is there a reset button anywhere on a vtech cordless phone?
remove battery for handset.
unplug power AND phone line to base unit.
wait 15 seconds or more.
reinstall battery.
plug in power to base.
plug in phone line to base.
put handset in base charger slot.
wait a minute or more for all to reload from ROM.
Oct 14, 2009 | Vtech Lands Phones
Can use the phone it is only reading searching on the display.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
Vtech i6772 Trio Cordless Phone Logo
65 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
