Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Remote control possibley defective
I have a westwind fan remote control. i recently replaced the bulbs w/ flourescents. these started to act erratically so i replaced them with the originals. now when i turn on the lights the're in a dimmed mode as if the unit is not getting enough juice. can anybody suggest a test solution for this problem?
Does your remote have a variable control for the bright and dim for the light??sounds like yu have it in the dim mode..
Posted on Apr 08, 2007
SOURCE:
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
My hunter ceiling fan light keeps turning on randomly, it has been installed for @3 years (just recently started doing this). I have a remote control
There may be another remote control in the room/house that is causing it to turn on. A member of my family has a fan that uses a remote, when they turn on their stereo it also activated the dimmer on their ceiling fan light.
step 1 would be to ensure that it isnt other remotes that are causing this to happen.
step 2 would be to replace the batteries in the remote for the fan. once they are replaced use the remote to turn on and off the functions that are being turned on randomly.
if it is not anything to do with remotes, have the person that put it in for you disconnect it from power completely to try to reset the control board.
if that doesnt help, you may have a defective product that needs to be replaced.
if this doesnt work, report back with some more detail and I will try to help.
Feb 28, 2013 | Hunter Dryers
My fan and light do not work and I was told that the relay needs to be replaced. Is that true and if so, where can I pruchase one?
If neither the fan nor the light work, check that there is power to the fan unit first. If it is remote controlled and there is power to the unit, any relays would be on a PC board inside the fan and will not easily be replaced.
Mar 19, 2011 | Westwind Classic Hugger Polished Brass 52"...
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
I have a designers DC remote which operates the fan and light fixture. one day we lost all power and then every thing worked even the fan but we can't get the lights to come on with the remote. Do you...
Does the fan/light fitting have manual switches, pullcords?
If so, are you sure the manual switch for the light is in the 'on' position? The remote will not override the manual switch, so it must be on.
Apologies if you have already thought of this.
Feb 28, 2010 | Westwind Traditional Designers Choice...
Manual for Hampton Bay remote controlled Fan Circa 2003 ?
Hold the glass shade with both hands on opposites sides and GENTLY turn it counterclockwise. You should have access to the bulb.
Oct 24, 2009 | Dryers
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Light flickers when dimmer switch isn't ''just right''
Compact fluorescent bulbs do not work on dimmers.  You have to use standard incandescent bulbs or not dim the lights.
Mar 20, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Under cabinet light not working
probably not defective bulbs. Flourescents use either a starter and transformer or a ballast. When lights are weak, could be either. Very simple to change too. One other thing, could be connections that go into the lamp holders. If not good connections, light will be dim. On a stretch, if unit is located in an area that us lower than about 50 degrees, this could cause them to be dim. Check ratings on ballast/ starter and transformer. Finally, if voltage is either too high or too low, this could be a dimming problem too. If it has worked in the past, and this is a current problem, then chances are it's not the voltage but may want to check it anyway to eliminate that possibility.
Feb 05, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Fan remote operates fan, won't operate light
If you press and hold the light button, it will step up in brightness to max then back down to dark. Then when you press the button briefly it will turn off and then press button briefly again it will turn on at the intensity you had it at last. So if you are one tick from off you may not notice it is "on" because it is dark. A second possibility is that you replaced the bulbs with a compact flourescent and they are not always happy with adjustable brightness, often they will be on or off, no middle ground. I recommend sticking with old school bulbs in the fan.
Sep 21, 2008 | Universal Remote Control Hampton Bay...
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
240 people viewed this question
Top Westwind Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
