Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
Soup boiked over on stove top
I need to know how to get scaled soup off the top of my burner.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
A one sided razor blade does wonders.
Posted on May 11, 2017
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Posted on Feb 27, 2009
I need info on how to build inexspensive rocket stoves for emergencys. Thank you
Here is a great step-by-step process posted recently on Instructables:
http://www.instructables.com/id/How-to-make-a-Rocket-Stove-from-a-10-Can-and-4-So/
Summary:
1. Mark and cut hole in No. 10 can
2. Mark and cut hole in a soup can
3. Cut the bottom off a 2nd soup can and fit in the first as an elbow
4. Cut and fit the chimney from soup can #3
5. Cut a hole in the No 10. can for the Chimney to go through
6. Assemble and fill the space between the 3 soup cans and the No. 10 can with insulation material, like Perlite.
7. Make a fuel shelf with soup can #4 that sits flat inside soupcan #1
8.stuff in some kindling, light and enjoy!
Note: a similar process could be done with bigger cans or other materials.
Dec 23, 2012 | YouTube Videos
Burner turns itself off on KESA907
Most likely the switch that controls that burner is the problem and needs replacing
Nov 11, 2017 | KitchenAid KESA907PSS Electric Kitchen...
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
1 IGNITER ON MY FRIGIDAIRE STOVE TOP SNAPS BUT DOES NOT LITE I DO HAVE GAS PRESENT
If the other burners are working and you hear gas and the sparking working, the burner may be clogged. This happened to me when some soup boiled over one time. Try lighting it manually. i.e. Hold a lighter, preferably one with long stem, while slowly turning on the burner. If the burner is clogged, you may need to hold the lighter in different places. If this succeeds, let it burn for a couple minutes and this may clear the burner. If it still doesn't work you will need to clean the burner. Most of the time the front and back burners share a sparker. Good luck and let us know how if this has sparked a solution.
Mar 27, 2011 | Frigidaire Kitchen Ranges
I have a Kitchenaid superba convection/gas oven model KGR1607hblg (?) I had soup overflow from the top burner and now the burners will not ignite. When turned on they will spark but nothing catches.
Make sure that all the soup was cleaned out of the little holes in the burner that the gas comes out of. You can use a toothpick or some other small object like that to try to clean them out
Mar 23, 2011 | KitchenAid Ovens
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Ge xl44 range gas smell
it's the safety valve, it's bypassing the gas. for you to put soup in there you will have to remove the oven burner. and put the soup on the tip of the orifice that's where the burner sits on.
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven door is locked
i took the grids off the burners and gently pushed a screwdiver in the gap between the top of the stove and the area where the lock is. Then i slid the lock to left. Presto! open!
Feb 29, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
353 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
