Question about SanDisk Sansa e250 MP3 Player
Sansa 250 my sansa 250 automaticaly shuts off after a simple tap or a knock at the back. It also has trouble turning on. I have downloaded the lates firmware too. please help
  • Anonymous Jan 08, 2008
    I tapped it and it went off and I can't get it back on. What should I do?
  • 4 Answers
Place paper between battery and battery cover. it seat the battery and charging mechanism better. it worked for me
Posted on Jan 21, 2008
Take it apart and make sure the battery hasn't loosened up at all.
Posted on Apr 05, 2007
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
My sansa wont turn on
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
this is their instructions not mine, but i hope this helps you.
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Sansa e 250 froze
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 17, 2008 | SanDisk Sansa e250 MP3 Player
Problem with my sansa e 250
-Tha Mp3 Doctor
Apr 15, 2008 | SanDisk Sansa e250 MP3 Player
My player is messing up
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 12, 2008 | SanDisk Sansa e260 MP3 Player
My sansa 250 e
try running your sansa out of battery so the screen shows [to low of battery] then plug in your sansa to your computer and resync your music
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
Sansa 250 off an on PC
-Tha Mp3 Doctor
Mar 07, 2007 | SanDisk Sansa e250 MP3 Player
E 250 is being a homo
-Tha Mp3 Doctor
Sep 10, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
77 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
