Question about Hitachi C29-F100 29" TV
It doesn't have a coax connection, what type do I need ?
This model tv doesn't have a coax connection, yet my COX cable is feed via coax ?
I had same issue. You need a converter between the cable and the tv. I found one for less than $3.
Posted on Mar 19, 2009
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
Tip
How to connect and record on a VCR when you have a Digital Cable Box.
Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
First here are the cables you will need.
3 sections of Coax cable (preferably RG-6 quality)
or
2 sections of Coax cable (preferably RG-6 quality)
1 RCA cable (Yellow/Red/White)
Now here is how you will need to hook up the cables properly.
1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
Now this is how you will need to set your VCR and Cable box to make your recording.
1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
2) Tune your cable box to the channel you wish to record.
*** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
on Jan 09, 2010 | Televison & Video
TV1 seems fine while TV2 continues trying to acquire the satellite signal. I've reset it several times via the front panel and by unplugging but nothing works.
robert_bunto
You may have a loose connection from your TV 2 feed. You can check the cables on the back of the receiver to make sure they are secure. Depending upon your installation, you could have 1 or 2 separators back feeding your TV 2 from the receiver to your TV 2. In the center of the receiver you have your TV 2 coax port. From that TV 2 port, check all points of connections to make sure the cables are secure and tight. If this doesn't resolve the issue, you may have a bad connector or switch, which would require a technician to repair. I hope this helps.
Ray Calo
DISH Network
Apr 19, 2011 | DISH Network DVR-625 DTV Receiver /...
Im am trying to connect my cox cable box to my LG computer monitor and if i try and input the screen just goes black
You can't directly connect any cable connections to a computer monitor. You will either have to connect the cable box to a network router or to your computer tower via stantard Ethernet cables if this is for Internet usage.
If you are trying to connect this for viewing "Cable/TV" content, then you would have to have some kind of TV card installed and connect the coax/antenna cable to that connection.
Aug 09, 2010 | LG Computers & Internet
VCR will play, but won't record
Your VCR has to be on the same channel as the switch on the back of you cable box.
Mar 05, 2009 | RCA VR557 VHS VCR
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Jan 10, 2009 | Vizio L32 32 in. LCD HDTV
Hooking up my dvd player
Try an "RF Modulator". It can take in multiple type signals like your cable and dvd and send it to the TV via the coax. The one I have will take in Coax (cable), RCA (left, right & Video) and S-video.
Dec 26, 2008 | Toshiba SD-4000
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
No recption pass channel 12
judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
trin
Nov 16, 2007 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi C29-F100 29" TV Logo
243 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
